Author Topic: Built engine requirements for 500hp  (Read 1669 times)
Offline 09Pirelli
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=rjt2lbuqidkglfr49ss5kcl7q2&/topic,133619.0.html
« on: October 18, 2023, 09:02:18 pm »
Hi all, im going stage 3 next year and am aiming for 450bhp, im considering doing rods and pistons for a more reliable setup, what are some good brands rated for 500HP, and what else should/need to upgrade, there is a 1000hp built engine kit from bar-tek i was looking at.
Idealy i want an engine capable of 500hp for a 'kill map'
i will be using meth with this setup
2009 Pirelli Edition Stage 2+
Re: Built engine requirements for 500hp
« Reply #1 on: October 20, 2023, 10:29:59 pm »
For 450-500 that will last more than 5 minutes, you will need:
TTE480 or equivalent turbo
Rods
Pistons
Intercooler - a big f'cker
ARP Rod bolts
ARP head stud kit
Stage 2 pump internals
TTRS lift pump
3.5" downpipe and probably 3" 'cat back'
A lot of tyres
A lot of petrol
A lot of engine oil
Ear plugs
Balance shaft delete. They won't cope with that much power and rpm.
1.8T oil pump conversion probably not a bad idea.
DSG remap to increase clutch clamping force, or better still, a beefed up clutch packs..... or beefed up clutch if it's a manual.
Fluidampr
150 bar fpr
Bigger injectors
You definitely don't want a kill map. A brill map is what you want. You will need to discuss mapping with your tuner as stock MAF housing size is borderline at that flow rate.
