Author Topic: Boost psi  (Read 1279 times)
Offline Dogg1210
Boost psi
« on: November 05, 2023, 01:30:57 pm »
Hi folks , what psi should a mapped gti be at my readings are saying roughly 11 to 12 psi thought it would be more than this. Car feels quick and is side by side with my mates mk3 focus rs on a roll
Took these from torque app not sure how accurate it is
Offline OllieVRS
Re: Boost psi
« Reply #1 on: November 05, 2023, 01:56:45 pm »
Stage 2 (Sports Cat, Intake) on the stock K03 turbo peaks at 16psi in 3rd and 14psi in 4th & 5th. Numbers taken directly from a VCDS log.
Either yours is stock or slightly mapped but I'd bet on the former.
A good way to check if it's mapped is to log Torque (NM) and then do an online conversion with the given RPM at that moment to check the HP. If it peaks above 210 (or 240 for ED30 GTI) then it's definitely mapped.
'06 Skoda Octavia vRS TFSI
Offline Dogg1210
Re: Boost psi
« Reply #2 on: November 05, 2023, 03:31:07 pm »
Just did a pull 3rd gear to redline strange that it's saying bhp is 280odd but boost is just over 10psi
Offline OllieVRS
Re: Boost psi
« Reply #3 on: November 05, 2023, 04:31:08 pm »
Is there anyway to check the RPM when you hit that second Torque peak? Something seems off, you MAF intake peaks around 175g/s, to be anywhere near 280hp you'd need above 200g/s.
Offline Dogg1210
Re: Boost psi
« Reply #4 on: November 05, 2023, 07:29:49 pm »
Sure the torque was at around 4k to 5k ill check tomorrow
Offline Dogg1210
Re: Boost psi
« Reply #5 on: November 07, 2023, 05:33:24 pm »
What is the timing advance this is it at idle
Offline Dogg1210
Re: Boost psi
« Reply #6 on: November 07, 2023, 06:08:17 pm »
Foot down in 2nd
