Author Topic: front control arm frint bushings  (Read 671 times)
Offline 9MAK
  • My Ride: ed30
« on: November 10, 2023, 05:33:43 am »
Hi, i’m going to be fitting s3 8p lower control arms soon and whilst in there i wanted to upgrade the front control arm bushings but i was wondering if it was worth me going for the camber adjustable bushings or not?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: front control arm frint bushings
« Reply #1 on: November 11, 2023, 06:45:18 pm »
I could be wrong, but I believe those will limit the minimum camber to more than the OE spec. I recall seeing their minimum you can achieve will be near -1.5°. I think our camber specs are -0.50° ±0.50°; so a max camber of -1.0°. This could obviously corrected, if you choose to do so, with a pair of upper adjustable camber plates.
I thought to get them, but I already get a bit of inner tread wear when it is within spec.
