Hello.
My 2006 GTi’s AC doesn’t operate - cooling fans are not running which I believe are controlled by relay in large fan.
I haven’t managed to unhook the connector on the AC pressure switch to test it but the fans do run when jumped from the battery so I’m pretty sure it’s the fan controller at fault. I have a P0480 fault - Cooling Fan 1 control circuit code too. Seem to be quite a few complete fans on eBay; are they all compatible? Mine has a AD suffix - 1KO.121.207.AD; there are a number with BC suffix from Golf and Audi diesels so wondering if their controllers will work?
Thanks.
PR
