Author Topic: Low pressure windscreen jets.  (Read 3163 times)
Offline GreigC
« on: December 12, 2023, 09:52:40 am »
Hi, I have an issue with my windscreen washer jets. They work… but initially when I press the stalk to operate the jets the pressure is so weak…. Then it bursts into life. I’ve removed both jets on the bonnet cleaned them and still the same issue. When I test the jets and look for any leaks under the bonnet I don’t see any. My xenon washer jets work no problem. Any common areas to check?
Offline mjmallia
Re: Low pressure windscreen jets.
« Reply #1 on: December 12, 2023, 10:42:14 am »
I had a single weak jet and thought it was the jet, then thought the pump.........but it ended up being a cracked hose at the bend below the left bonnet hinge.
Replaced the pipe and full pressure returned
Mike
South Coast
Offline GreigC
« Reply #2 on: December 12, 2023, 08:48:10 pm »
Thanks for the reply….I’ll have another look. Do you have a part number for the pipe?
Offline terrier
  • -Receive: 39
  • My Ride: GTI now gone
« Reply #3 on: December 13, 2023, 01:08:45 pm »
Try this 1J0 955 998 F  Just ordered a replacement as the white elbows 3B0955665C on mine are cracked
 Lucky for me mine packed up 3 days after MOT day
Offline GreigC
« Reply #4 on: December 14, 2023, 05:01:42 pm »
I’ve purchased a repair kit for the hose at the bonnet hinge. I’ll give this a go and report back. Thanks again for the replies and information.
