Author Topic: Car starts then dies  (Read 1481 times)
Offline T4yy18
« on: December 17, 2023, 09:12:15 pm »
Hi i have a mk5 git 2007 bwa
Recently i had installed ecs tunings high flow intercooler pipes for inlet and outlet. After when i turned the car on it would start then die after a few seconds. I unplugged the maf sensor and the car stayed running.
I dont have vcds but do have a cheap scannner and found codes for maf sensor and  p2261 for divortor valve. I changed the diverter valve for a genuine rev g and borrowed a maf sensor off another gti and clear the codes. Started it and it lasted a bit longer but still died.
There was another senor that was on the inter cooler pipe to throttle body but i used the same sensor and it was plugged in ok
Does any one have any clue to what could have happen?
Offline mjmallia
  • -Receive: 54
Re: Car starts then dies
« Reply #1 on: December 18, 2023, 08:42:29 am »
Sounds like a major vacuum leak.  Re check your hoses to the IC
Mike
South Coast
Offline T4yy18
« Reply #2 on: December 29, 2023, 10:13:14 pm »
Hi i rechecked the pipes and they are all tight but still cuts out with maf connected
