Author Topic: EPC issue!  (Read 657 times)
Offline Jabethell
  • Newbie
EPC issue!
« on: December 18, 2023, 03:45:45 pm »
Hello
Mk5 GTI golf BWA engine.
So I’m getting a EPC light and EML. I’ve replaced the spark plugs, coil packs, HPFP, cam follower, HPFP plug and the N80 plurge valve. After replacing the parts the car did work but only for about 5 minutes and it went back to running really rough with the EPC and EML. I’m currently getting the following codes:
P0659 - actuator supply
P0458 - evap
P2295 - fuel pressure regulator 2
P0031 - H02s heater control
P2293 - fuel pressure regulator 2 performance
Most garage I’ve called can’t do anything and my nearest VW specialist is booked up until mid Jan. It’s worth noting that the issue has gotten worse to the point where it can’t be driven. I’m at my wits end! Any help will be really appreciated
« Last Edit: December 18, 2023, 06:50:18 pm by Jabethell »
