Author Topic: Central Electronics & coding issues  (Read 1062 times)
Offline MrFernze
« on: January 14, 2024, 10:55:46 am »
Hello Everyone,
I'm having an issue with my car not communicating with the rear doors. I believe it may be a communication issue between the Central Conv, CAN GW and Central Elec. Previous to this, my rear door's never locked since I had the car so I had to manually lock them. I thought I'd purchase some doors from a breaker due to my old ones having scratches and dents and the old ones were not working. So after installing them I'm still in the predicament of the doors not working. I recently installed new actuators on the rear doors, they did show some connection for a short time period when opening and closing the windows but shortly stopped. I've been looking online and I have seen some threads https://www.mk5golfgti.co.uk/forum/index.php?topic=24735.0 and read some other areas, my worry is that I've taken some doors that are not compatible with the CECM as they were from a breaker (My car is a 2005 AXX). I'm sure I have incompatible CECM, BCM & CAN GW. However, I would like to update these so I can keep upgrading the interior and have my doors lock without issue. Other than purchasing the BCM (3C8937049AB), do I need to also purchase an updated CECM (1K0959433CB) or am I overthinking all of this. I have added code and photos of each module's code for better understanding.
Code: [Select]
Sunday,14,January,2024,10:01:51:02823
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ6W022316   License Plate:
Mileage: 226250km-140585mi   Repair Order: 111
Chassis Type: 1K-VW35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W022316   Mileage: 226250km-140585miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2321880
   Coding: 040300031C070060
   Shop #: WSC 01279 785 00200
   VCID: 2411E0CC72DB4F5A6BB-8070
   VINID: 9E69EAAAA05BA869C00820C11898CAA7C1
4 Faults Found:
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 226257 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:03:40
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 8.0 C
                    Temperature: 6.0 C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.446 V
005635 - Internal Control Module
               P1603 - 004 - Failed Self-Test - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 226257 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:03:40
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 8.0 C
                    Temperature: 6.0 C
                    Voltage: 12.446 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 226257 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:03:41
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 8.0 C
                    Temperature: 6.0 C
                    Voltage: 12.446 V
008214 - Intake Manifold Flap Position Sensor (Bank 1)
               P2016 - 002 - Short to Ground
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 226257 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:03:41
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 8.0 C
                    Temperature: 6.0 C
                    Voltage: 12.446 V
Readiness: 0110 0100
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000601111214
   Coding: 0000020
   VCID: 1471B00CA27B3FDA9BB-8040
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 40D94C5C8683737A6F3-8014
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 5K0 907 044 HA    HW: 5K0 907 044 HA
   Component: Climatronic   H19 1414
   Revision: 00001004
   Coding: 0010004003
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW36.rod
   VCID: 71BFD998F129AAF2D0D-8024
9 Faults Found:
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [00001001] - Actuator Stuck
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
9472882 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [00001001] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
13701376 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Motorsteuerger t - kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
13701424 - Function Restricted due to Missing Message(s)
          [Steuerger t f r Bordnetz - kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
13701456 - Function Restricted due to Missing Message(s)
          [Steuerger t im Schalttafeleinsatz - kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
13701520 - Function Restricted due to Missing Message(s)
          [T rsteuerger t hinten links - kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
13701536 - Function Restricted due to Missing Message(s)
          [T rsteuerger t hinten rechts - kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
9481748 - High Pressure Sensor
          B10AE 14 [00001001] - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [00001000] - Open or Short to Plus
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 226257 km
                    Date: 2000.00.00
                    Time: 19:10:08
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001950675
   Coding: E58D0F2700041800001400001400000000087F075C
   VCID: 2B030BF01F058022AA1-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 01279
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 01279
9 Faults Found:
00906 - Horn (H1)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01495 - Bulb for High-Beams; Left (M30)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01499 - Bulb for High-Beams; Right (M32)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0G7CH4
   Coding: 0012870
   VCID: 372B2780D34D34C2DE9-8062
   Subsystem 1 - Serial number: 6332MSME0F3C7A41N
   Subsystem 2 - Serial number: 6342MSME12106670
   Subsystem 3 - Serial number: 6351HSME075C47709
   Subsystem 4 - Serial number: 6361HSME075E4C0FP
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
            001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012112
   VCID: 77ABE78093CDF4C21E9-8022
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   Shop #: WSC 00011 067 57207
   VCID: 6E85C2E4EC97B50ACDF-803A
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0231
   Revision:   H16       Serial number: 4320K09A2501A2
   Coding: ED807F06000202000003
   Shop #: WSC 06314 123 12345
   VCID: 698FB1F8D579523298D-803C
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 226257 km
                    Time Indication: 0
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
   Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0972
   Coding: 0000692
   VCID: 382924BCDE533BBAD73-806C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 234    2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F3B1FE02B1DFC02869-807A
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 226257 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:10:07
             Freeze Frame:
                    Battery Volts: 12.1 V
                        DD
                    Temperature: 5.0 C
                    Count: 2
                    Steering Angle: 0.00
                    Count: 1
                        SteerAng n.Init
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01C802087F2D8C0D485FC69010CC
   Shop #: WSC 12345 785 00200
   VCID: 79AFE1B8A5D9E2B268D-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
3 Faults Found:
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000692
   VCID: 392F21B8E55922B228D-806C
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End----------(Elapsed Time: 01:03, VBatt start/end: 12.0V/12.0V)-----------
« Last Edit: January 14, 2024, 10:59:44 am by MrFernze »
