Author Topic: Boot lid  (Read 1384 times)
Offline Dave4597
Boot lid
« on: February 12, 2024, 07:46:33 pm »
Hi, having problems with my mk6 gti rear boot lid stopped working and won’t open from outside. Can’t hear the motor working or nothing. Tested the boot switch with vcds and when operated it changes on measured values so that would mean the switch is working ok. Then when doing an actuator test with vcds on rear boot latch it opens it so far all good. Checked both wires from the switch and all reading ok then checked wires from the latch and all ok aswell. Could there be a problem with j519 not sending the signal to open the latch? Or has anyone came across this issue before?
