Author Topic: Can't Communicate with Rear nearside Passenger Door - Golf GTI Mark V 2007  (Read 1901 times)
Offline NTmk5golfgti
  • My Ride: VW Golf GTI Mark V 2007 Reflex Silver
Hi Guys
Hoping for some advice on an ongoing issue.
About a month ago the central locking on my rear left hand side passenger door stopped working. Door would not lock/ unlock from key fob or drivers door switch. It stayed in the locked position. It would not open from the inside using the rear door interior lever. Only way to get it open was to use interior lever and exterior handle on rear door at the same time. To lock it, have to use the key pressed through the emergency lock hole on the door (after removing the rubber cover). Electric window on door does not work either using the rear door or driver door controls. I've run a scan and VCDS tells me that it cannot even reach the rear door control module so no communication with it. I've replaced the rear door wiring harness with a brand new VW one and replaced the lock module  with a Fibi Belstein new lock module. I've also replaced the rear door motor/ control module. Still nothing works and still no communication. I've taken the driver's door card and outer skin off and can't see anything wrong. All other doors operate normally as they should. Last VCDS scan is below. The car went in for a major service last week at VW Sevenoaks. (teh problem existed before this). All they indicated was that there was a problem with the rear door window that would need investigating (£120).
 Latest scan below, which identifies a wrong coding issue in a module but I can't seem to find one with the rear door module. Could it be a coding issue with driver's door module? I replaced the radio/CD player with a VW Sat Nav system early last year (Sat NAv system was one that arrived with last editions of Mark 5 and featured in Mark 6) and installed a new Canbus gateway module (to avoid battery drain issue) early last year with no problems. All doors were fine including rear passenger n/s one.
I'm at a loss and would welcome any advice/ suggestions. Not keen to fork out on a new driver's door wiring harness (£200) or driver's door window motor/ control module (£££+) just yet in case it's a coding issue.
(the car is very low mileage - 49,000 and the iding problem has already been fixed)
Tuesday,13,February,2024,10:52:15:02870
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN:   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72
VIN:   Mileage: 76590km-47590miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Not registered 0011
37-Navigation -- Status: Not registered 0001
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G53NQ8L7
   Coding: 0403000318070060
   Shop #: WSC 01279 785 00200
   VCID: 343216A2B23BDCCAFBB-8060
   VINID: 9E69EAAAA05BA889C010424600A9557AC3
1 Fault Found:
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected.
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 76494 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:21:17
             Freeze Frame:
                    RPM: 874 /min
                    Load: 22.3 %
                    Speed: 0.0 km/h
                    Temperature: 88.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   VCID: 73B0D5BEF7B59BF2221-8026
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 79ACE796D5D9E1A268D-802C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000007286445
   Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 71BCDFB68DA9A9E2D0D-8024
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 200607 021  0501
   Coding: 00038805
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     020707 046  0204
   Coding: 00208933
   Shop #: WSC 00000
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 142
                    Mileage: 76494 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.85 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1AT2JO
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D24338681711D82045-8068
   Subsystem 1 - Serial number: 6332MSME1C046629B
   Subsystem 2 - Serial number: 6342MSME1C280F56L
   Subsystem 3 - Serial number: 6352QSME2F31494BQ
   Subsystem 4 - Serial number: 6362QSME2D2C7773V
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   VCID: 74B2D6A2F2BB9CCA3BB-8020
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 964     HW: 1K6 920 964
   Component: KOMBIINSTRUMENT VDD 1214
   Revision: V0002000    Serial number: VWX7Z0G53NQ8L7
   Coding: 0003403
   Shop #: WSC 56544 004 1048576
   VCID: 70BADAB286A3A0EADF3-8024
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 190608F2002893
   Coding: E9807F060002020003
   Shop #: WSC 00028 028 00001
   VCID: 35342BA6B941C5C2CC5-8060
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 76494 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:21:12
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 93
                    Reset counter: 255
                    Mileage: 76494 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:21:11
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1214
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662723830
   Coding: 010100
   Shop #: WSC 01357 011 00200
   VCID: 2A0E08DA6CFF9A3A517-807E
1 Fault Found:
03138 - Input AUX IN
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 0 km
                    Time Indication: 0
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 Q    HW: 1T0 035 680 Q
   Component: RNS-MID       H10 5270
   Revision: AB001001    Serial number: VWZ6Z7M9128083
   Coding: 00000400000000800000
   Shop #: WSC 14101 009 14102
   VCID: 3C223E82966B148A33B-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V11  8117
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         006 120B
   Coding: 0000692
   VCID: 382A2292AE5338AAD73-806C
3 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
            012 - Electrical Fault in Circuit - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 36362CAAA447CEDAC5F-8062
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 819002005103087F2D04840570085FC690FCA0
   VCID: 0350857EA715AB72321-8056
   Subsystem 1 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000692
   VCID: 392C2796955921A228D-806C
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Component: Tuer-SG         006 1207
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.2V)-----------
NTmk5golfgti
Offline QueenLizz
Re: Can't Communicate with Rear nearside Passenger Door - Golf GTI Mark V 2007
« Reply #1 on: February 17, 2024, 09:23:47 am »
Ok so a few things. The door modules if not OEM and replaced could be a different variant i don't think some parts of the world got deadlocks (safe lock) others did, drive on other side of road so maybe locks referred to wrong, maybe lite up doorlocks that sort of thing. This would account for coding errors and communication ones. Also there are 2 modules in the doors IIR one is the door lock mechanism itself. The other is the window up/down regulator motor. I think the wiring for the lock goes through the window regulator? So its possible that's actually at fault and not the lock module. Your best bet would be to get things reset to default values. The features and things enabled should be the same for left/right hand rear doors so you could go through the one thats working and check for differences.
The one door fault says intermittent also implying it had some communication issues but has managed to connect at some point (would hint at a power/earth/switch issue) was this an old code and has it came back since clearing codes?
« Last Edit: February 17, 2024, 09:28:01 am by QueenLizz »
« Reply #2 on: February 17, 2024, 11:15:58 pm »
thanks for the response and advice.a reset to factory coding may be the way to go. i can’t see what values are in the control
module for rear passenger door as vcds can’t reach it so can’t  check its coding. i can’t figure out what the coding error is that’s referred too/ i’ve gone through the coding for the drivers door and the convenience control module and all seems fine but i’m no expert.
thinking about it further i think i have to try  replacing the drivers door locking module (ordered used one from vwstevens) and the main wiring harness (becoming quite hard to get these now it seems). MOT coming up end of feb…thanks again
NTmk5golfgti
Offline QueenLizz
« Reply #3 on: February 18, 2024, 02:54:42 pm »
Best of luck bud.
Re: Can't Communicate with Rear Passenger Door - Drivers Door now deadlocked
« Reply #4 on: February 28, 2024, 06:02:24 pm »
Hi
Thought I'd provide an update on progress.
Whilst trying to solve the issue of no communication with rear n/s passenger door, the Drivers door intermittently stopped locking and had to use but key to lock/ unlock it. I bought a replacement lock module from VWStevens (VW breakers) and fitted it. Drivers door would now close but not lock at all. Refitted original locking module, could not get the door to fully close so couldn't lock it. No amount of adjusting the position of the lock module would rectify this. So bought a genuine VW locking module from TPS  (£250) and fitted it yesterday. Tested it mechanically before closing the door and all seemed fine. I closed the drivers door (it closed perfectly) and locked it with the key fob. Success, it locked. EXcept now it will not open - from the inside or outside. I cannot get the door open at all. Whilst I'd put the outer skin back on, I'd left off the plastic trim along the inside edge of the door (one that hides all the bolts). I took the skin off the o/s rear passenger door which enabled me to access the driver's door locking cradle screw (Torx 20) in order to remove the driver's door handle. This gave me access to the tension wire for the lock, which I've pulled but the door still will not open.  I'm completely flumoxed by this. I now can't get the driver's door open at all. Any advice/ suggestions would be very much welcomed
NTmk5golfgti
Offline GreigC
« Reply #5 on: February 28, 2024, 06:15:00 pm »
Which wiring did you replace out the two pictured?
« Reply #6 on: February 29, 2024, 12:48:58 am »
hi, thanks for the response. your images are for the rear passenger door, which has one wiring harness that runs from the locking module (your bottom image) down through the rubber boot (your top image). i replaced that harness. i also replaced the similar harness for the driver’s door- both new original vw parts from TPS.
NTmk5golfgti
Offline GreigC
« Reply #7 on: February 29, 2024, 03:33:07 pm »
Ah I see, I thought the rear had two looms like the front. Sorry about that. My advice would be taking the car to a specialist considering what you’ve checked/replaced already.
