Author Topic: Mk6 1.6tdi epic spec  (Read 2540 times)
Offline Mk60ben
« on: February 29, 2024, 07:29:23 pm »
MY 2011 1.6TDI BLUEMOTION S
MODIFICATION LIST
ENGINE
1.6tdi CR105  CAYC
Darkside DPF delete pipe
EGR delete
GTC1549VZ turbo upgrade
Turbo discharge damper Delete
S3 Alloy intercooler
Darkside tip pipe
Racingline Cold air intake system
Stainless 2.5" straight throw exhaust with Dual exit with 4.5" Akrapovič tips.
210a alternator dereged running 15.2v
Stop/start  and smart charging deactavated
Front battery delete
Gold wing/headlight bolts
HG Motorsport Billit alloy coolant bottle cap
HG Motorsport BIllit alloy washer bottle cap
HG Motorsport Billit alloy Engine oil cap
Tuned to
184bhp@4048rpm  279.2lbft@2672rpm
TRANSMITION
Darkside silent flywheel and saschs clutch kit
Creations Motorsport short shift
Creations Motorsport gear cable end solid bushings
Clutch pedal stop modified to reduce travel
EXTERIOR
Genuine GTI ED35 front and rear bumpers (smoothed)
Genuine GTI rear bumper
Carbon fiber GTI grill with carbon TDI badge
Maxton design ver.2 front spliter
Maxton design side skirt diffusers
Maxton design rear diffuser
Front fog lamps added and light switch
Front fog light grills
Carbon fiber mirror covers
Carbon fiber z1777 rear boot spoiler
Carbon fiber wraped B piller trims
Carbon fiber front and rear badges
Tinted windows
Tinted sunstrip
Osram Xenarc Black headlights with xenon converted to LED bulbs
Osram black dynamic side repeaters
Osram rear dynamic LED rear lights (LHD)
Autobeam RGB app controlled fog lamp bulbs
Autobeam RGB app controlled underglow kit
Autobeam led registration bulbs
Grill mounted clips for registration plate
4D registration Private plate MK60 BEN
Gtechniq G1 glass sealent
Gtechniq C5 wheel armor
Gtechniq C4 on plastics
Gtechniq CSL and evo4 on paint
Gtechniq T1 on tyres
INTERIOR
Mk7 style key
Mk7 buttonless leather steering wheel red stiching
Mk7 swade airbag
Swade gearstick boot with red stiching
GTI tarten seats
Likewize Ghost gear knob and new boot
Sunglasses holder
Arm rest
Carbon handbrake trim
Genuine mats
2x USB ports added by gearstick
TPMS coded in
Big speedo and needed sweep coded
Carbon insturment dials blue needels blue leds
Cruise control added
Passat W8 roof light
Lower door led curtesy lights added
Osram LED blue bulbs
Autobeam RGB footwell lights
Pioneer sph-da360dab headunit
Focal component set
Focal Coaxial speakers added to rear doors
Bass knob by gearstick
Vibe micro box hidden behind dash running door speakers
Pair of sundown NSv4 12" subs in custom enclosure
Sundown SFB13500d amp
160ah of yinlongs lithium batterys in the boot
Two runs of 70mm2 power cable to front uprated 210amp alternator.
150.12db@28hz with a pair of 10s yet to test the 12s
3-5 layers of 2.5mm anti-vibe deadener on inner body panels
1 layer of foam deadener
Tinted windows
Tinted sun strip
Thinkwear F770 front and rear dash camreas
SUSPENSION/CHASSIS
APB Air bag Kit
Bilstein shocks
Air lift 3P 3/8th managment
Pair of ABP X444U Silent Compressors
Pair of 2 gallon seamless air tanks
Ground control adjustable top mounts
Racing line cup edition  front &rear bushings
Deadset kit
S3 front alloy hubs
S3 alloy control arms
S3 solid control arm rear bushes
Racingline front 26mm anti-roll bar
Racingline rear 21mm anti-roll bar
Racingline ARB front links
Front and Rear subframe dead set kit
034 motorsport torque support insert
WHEELS/TYRES
Compamotive TH2-1881 satin bronze 8x18 et35.
5mm spacers
Racingline stud/nut kit
Mitchelin pilot sport 4 225/40R18 92Y XL
BRAKES
Front
TTRS 8J 4pot brembo calipers
370mm 2 piece floating discs J-hook
Yellow stuff pads
HEL performance Braided hoses
Audi RS3 brake ducts
MK5 R32 rear calipers painted blue
310mm J-hook discs
Ultimax pads
Neo titanium bleed nipples
Motul RBF660 brake fluid
Instagram Ben.lee.102
« Last Edit: March 15, 2024, 10:42:33 pm by Mk60ben »
Offline Jons1001
Re: Mk6 1.6tdi
« Reply #1 on: March 01, 2024, 06:47:55 am »
Wow there's some work gone into that  :congrats:  :notworthy:
But how do you get over speed bumps?  :scared:
Offline Mk60ben
Re: Mk6 1.6tdi
« Reply #2 on: March 02, 2024, 07:39:32 pm »
Thanks. Buy rasing the suspension
Offline Mk60ben
Re: Mk6 1.6tdi epic spec
« Reply #3 on: March 30, 2024, 11:51:44 pm »
