Author Topic: Front Wiper Issue  (Read 1596 times)
Offline Jons1001
Front Wiper Issue
« on: March 06, 2024, 09:45:01 am »
Hi, i've got auto wipers and the front wipers have stopped working on the first setting (1 notch up). The other settings work fine.
Any ideas?
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Re: Front Wiper Issue
« Reply #1 on: March 06, 2024, 09:58:56 am »
Check there is no obstruction to the rain sensor (bird poo etc) could be rain sensor itself test with water spray bottle.
Sent from my Pixel 4a using Tapatalk
Offline Jons1001
« Reply #2 on: March 06, 2024, 03:00:49 pm »
Hi mate thanks for the reply. No obstructions i can see. Perhaps i didn't explain it too well though... usually when i turn the wiper on manually (up one click from off postion) it will do at least one wipe regardless if the screen is wet or not. Now it does not.
Possibly being thick here but is it only the first click that is the rain sensor? And then others are just set speed? If so as you say could be the sensor is knackered.
« Last Edit: March 06, 2024, 03:02:38 pm by Jons1001 »
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #3 on: March 06, 2024, 05:35:31 pm »
Could be rain sensor or the stalk itself, do you have vcds to check for codes?
Offline Jons1001
« Reply #4 on: March 07, 2024, 10:30:31 am »
I've got ODB11 so will give it a scan and see if it comes up with anything. Thanks
