Author Topic: Throttle body  (Read 1945 times)
Offline bilal
  • Newbie
Throttle body
« on: April 04, 2024, 04:40:48 pm »
Hello, ive had a code come up on my mk5 gti PO221, regarding the throttle position sensor and body. I replaced both and still have the same issue, just wondering what else could it be. I have replaced the pedal to check if that was the issue but nothing changed, car still had the same issue. I have also tried taking the codes off via vcds but they come back straight away, even after replacing throttle body. Help would be appreciated
« Last Edit: April 04, 2024, 05:56:27 pm by bilal »
Offline TheBALDpuma
Re: Throttle body
« Reply #1 on: April 04, 2024, 08:30:23 pm »
I had a throttle body issue a few years ago, made the car un-driveable eventually.  I changed the throttle body, flashed the ECU but was still having issues. It turned out to be the wiring loom to the throttle body.
Offline bilal
  • Newbie
Re: Throttle body
« Reply #2 on: April 04, 2024, 08:32:29 pm »
Thank you, how easy is the fix for the wiring loom and do you remember how much it was.
