February 01, 2025, 02:45:18 pm
All Things Mk5
Mk5 General Area
K03 turbo outlet diameter
Topic: K03 turbo outlet diameter (Read 1061 times)
ajmludders
Newbie
-Given: 0
-Receive: 0
April 10, 2024, 10:43:15 am »
I am thinking of upgrading the full exhaust system from the OEM stock but wondering if a 3-inch system will fit onto the stock k03 turbo mounting?
So for example would a Miltek 3-inch downpipe fit onto the K03 turbo mounting?
Thanks in advance!
ZoliWorks
Always Involved
-Given: 5
-Receive: 16
Re: K03 turbo outlet diameter
Reply #1 on:
April 19, 2024, 07:53:36 am »
A 3 inch will be overkill for the K03 but will work if you later plan on going K04 because they use the exact same hot side downpipe mounts. Measurements are in cm.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
ajmludders
Newbie
-Given: 0
-Receive: 0
Reply #2 on:
April 19, 2024, 12:45:22 pm »
Thank you that's really helpful.
All Things Mk5
Mk5 General Area
