Author Topic: How install a k03 hybrid (considerations)?  (Read 676 times)
Offline javihere
  • Newbie
« on: June 06, 2024, 08:31:03 pm »
Hello all guys.
I have a golf 5 gti with code motor axx and I want to change the stock turbo k03 for an hybrid k03 and do a remap of the ECU.
BTW, the rest of the car is fully stock.
Can you please tell me if I have to take any special consideration for the installation or extra hardware that I will need to buy?
Thanks in advance for the support  :smiley:
« Last Edit: June 11, 2024, 09:02:31 am by javihere »
Offline ZoliWorks
Re: How install a k03 hybrid (considerations)?
« Reply #1 on: June 08, 2024, 01:14:29 pm »
https://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/63-ENGINE-Replacing_Your_Turbo/63-ENGINE-Replacing_Your_Turbo.htm
Pretty much follow this article. Change seals, studs and nuts as those are one-time use. If it's a direct fit hybrid turbo, you don't need anything extra other than all parts you need for a normal turbo replacement.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
