Author Topic: Help with buying MFSW module  (Read 1116 times)
Offline CrniPetak
« on: June 09, 2024, 07:03:59 pm »
Hi everyone, i decided to retrofit highline instrument clusters and MFSW but my module is 1K0 953 549 AF. I looked at rosstech but i dont know which module i need to buy. Can someone help me with this? Sorry for bad english :smiley:
Offline mjmallia
  • -Receive: 54
Re: Help with buying MFSW module
« Reply #1 on: June 10, 2024, 09:52:30 am »
What cluster PN do you currently have.  The early highline ones ending 970, 971, 972 (to 2006 roughly) can be reprogrammed DIY style
https://www.mk5golfgti.co.uk/forum/index.php?topic=91363.0
The steering wheel modules vary also, and have to match to the slip ring.
So one ending in G, AG, AJ, AK, AL etc
You need to get a highline type 2 module that is, as yours is a midline type 2
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
« Last Edit: June 10, 2024, 10:18:33 am by mjmallia »
Mike
South Coast
Offline Octoparrot
  • -Receive: 102
« Reply #2 on: June 10, 2024, 09:55:07 am »
1K0-953-549-CH should work.
Offline mjmallia
  • -Receive: 54
« Reply #3 on: June 10, 2024, 09:55:42 am »
Then there is the VCDS coding of it all
https://www.uk-mkivs.net/threads/how-to-multifunction-steering-wheel-mk5-golf-h.10129/
Done a few cars in the past, and you have to follow the procedure exactly, otherwise the coding does not take and you have to start from the beginning again.
Mike
South Coast
Offline mjmallia
  • -Receive: 54
« Reply #4 on: June 10, 2024, 09:57:29 am »
Mike
South Coast
Offline CrniPetak
« Reply #5 on: June 10, 2024, 10:49:03 am »
I am still searching for those clusters so i dont have it right now. Someone mentioned that module ending with CH should work but i see that CH module is other SW versiom than mine, does that matter?
Offline mjmallia
  • -Receive: 54
« Reply #6 on: June 10, 2024, 01:37:32 pm »
SW version if the same or newer is fine.
Mike
South Coast
Offline CrniPetak
« Reply #7 on: June 10, 2024, 03:25:50 pm »
So 1K0-953-549 CH should work?
Offline terrier
  • -Receive: 38
  • My Ride: GTI now gone
Offline mjmallia
  • -Receive: 54
« Reply #9 on: June 10, 2024, 08:57:22 pm »
CH command strong prices for some reason. The AG and others in the list will work just as well
« Last Edit: June 10, 2024, 09:03:08 pm by mjmallia »
Mike
South Coast
Offline terrier
  • -Receive: 38
« Reply #10 on: June 13, 2024, 05:42:09 pm »
Because the sellers know why we neeeed them :happy2:
Offline mjmallia
  • -Receive: 54
« Reply #11 on: June 14, 2024, 08:09:51 am »
Yes, just not sure why the focus is on the CH as there are many other versions available  :laugh:
Mike
South Coast
