Author Topic: Oil recommendations for dsg service mk5  (Read 1249 times)
Offline Conork234
  • Newbie
« on: July 01, 2024, 10:03:53 pm »
Hi all, I recently purchased a mk5 gti auto, the last dsg service was 2019 but has only done 20,000km since so to be on the safe side I’m going to service it. I’ve been recommended liqui moly and valvoline if anyone else has any suggestions for an alternative oil to the OEM
Thanks a mill
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Oil recommendations for dsg service mk5
« Reply #1 on: July 02, 2024, 02:56:00 pm »
Id just stick to OEM, its not that far off price wise to other products.
Offline Conork234
  • Newbie
« Reply #2 on: July 02, 2024, 03:21:52 pm »
Thanks a mill for your reply, is there any difference between g052182a2 oil and g052182?
Offline Jons1001
« Reply #3 on: July 02, 2024, 04:26:27 pm »
This. I always look on ebay to see if i can get it a bit cheaper, just make sure the dates are ok.
Offline lazy
« Reply #4 on: July 02, 2024, 08:03:56 pm »
I was thinking of using Febi Bilstein. You can get the oil and filter for just under £100.
Correct me if I'm wrong but don't they make OE stuff.
Any thoughts on me using this.
« Reply #5 on: July 05, 2024, 09:53:36 pm »
Febi is not an OE supplier.  For something as important as the gearbox, genuine oil only.
Offline lazy
« Reply #6 on: July 24, 2024, 07:16:30 am »
I phoned TPS to get a DSG service kit and was asked did I want 5 or 6 litres, so asked for 6 just to make sure I had plenty. On all things I've seen and read it was saying usually 4.5 - 5 litres drains out. I'd noticed some oil gathering around the filter head so thought it was going to be a bit lower, but when I drained it roughly 3.4 litres came out so I thought it had lost a lot oil. Then when I came to fill it, it only took slightly more. Then I ran it up to the correct temperature and drained the excess off and I worked out it took roughly 3.6 litres. The work was carried out on a 2 post ramp so vehicle was level and I'm 100% positive it was done correctly, it's actually quite an easy job if you have an OBD scanner that can tell you the ATF temperature.
If anyone else has serviced DSG gearboxes I'd like to know is mine and outlier or is this a normal amount of oil.
« Reply #7 on: August 02, 2024, 11:54:22 pm »
The gearbox will take what it takes as it has that special levelling tube.  Some quoted capacities are dry rated, but oil changes will have residual fluid left in the box you can't get out.  So long as the fluid drips out at the prescribed temperature range, I wouldn't worry about it.  With DCT gearboxes, you will soon know if its under filled as the shifts will be jerky and terrible.
