Author Topic: OEM straight fit with CD/DAB/Bluetooth  (Read 881 times)
Offline dennis10
« on: July 03, 2024, 10:26:31 am »
Hi fellas,  New Edition 30 owner here (57 plate, but Feb 08 registered)
Please can someone recommend the best OEM VAG stereo upgrade I can fit without having to mod that has a CD player, bluetooth and DAB?
I currently have a poverty spec OEM FM tuner / CD stereo in there with a broken LCD screen, so it's coming out at some point, but I want OEM and with the above if possible.  I'm not bothered about sat nav, but if it has this and DAB, what will I have to fit in addition to get it working with regards to aerials/additional loom?
Many thanks in advance!
Offline mjmallia
  • -Receive: 54
Re: OEM straight fit with CD/DAB/Bluetooth
« Reply #1 on: July 03, 2024, 01:05:02 pm »
I have the RCD510DAB in mine.  I had to retrofit the OEM DAB antenna from a Mk6, but all works fine.
I also have the FISCON Bluetooth module that connects to it and allows the phone button to work.
Mike
South Coast
Offline dennis10
« Reply #2 on: July 03, 2024, 10:20:54 pm »
The DAB antenna from the mk6, is this a fakra connector?  Where does it fit in the vehicle?
I've just purchased an RNS315 with DAB and bluetooth and have checked my CAN gateway and is thankfully this revision:  1K0 907 530 L - Which apparently is what I want to avoid the battery drain issue, so no having to upgrade the gateway in addition.
I just need to sort out microphone, GPS and DAB aerial connections
