Author Topic: Bunch of fault codes  (Read 736 times)
Offline MartinNorhave
« on: July 27, 2024, 09:26:32 pm »
I have a bunch of fault codes where I don't know where to start. I hope you can help me :)
1. 01809 (Left temperature flap positioning motor (v158)). I changed the motor and calibrated it by the hvac controls. Still get the fault code. Did some output tests and I moves fine using vcds. Any ideas?
2. 00470 (Combination comfort databus in single wire- open circuit). The code is stored in the gateway and all 4 doors. I checked the wiring from the car to the doors and none of the wires seem to be damaged. Any ideas?
3. 01134 (Alarm horn- no signal/communication (H12)). From what I can tell by looking online it is just a matter of replacing the alarm horn. Does anyone know where I can get an aftermarket one? The OEMs are pricey af.
