Author Topic: Mk6 Golf R Swap  (Read 797 times)
Offline TimHymers
  • Newbie
Mk6 Golf R Swap
« on: August 18, 2024, 06:18:07 am »
Hi Guys,
I have Mk6 Golf R swapped my Mk5 GTI. I have done the engine, trans, AWD, suspension, brakes and interior. Basically everything thats not an exterior item..
The car is running and driving and most things are working, but I need to sort the head and tail lights.
The connectors are different on the Mk6 and as i’m running the Mk6 wiring loom I need to de pin the connects and swap the plugs over from the Mk5 loom. Does anyone have wiring plans they can share for the head and tail lights?
Re: Mk6 Golf R Swap
« Reply #1 on: September 07, 2024, 11:57:52 am »
Well done, thats quite the retrofit  :happy2:
If you can't find a leaked ELSA wiring diagram source, one of those AutoData type online manuals will probably suffice. They're cheap with a 1 month subscription, which should be enough time to do what you need to do.
