Author Topic: MK5 GTI Creaking Sound After Revs  (Read 1703 times)
Offline Chaustars
  • Newbie
« on: August 22, 2024, 06:59:02 am »
Accidentally sent it over a pothole yesterday. Checked underneath for any leaks/scraping but haven't noticed anything. Might be my overthinking but this doesn't sound normal.
Offline mjmallia
  • -Receive: 54
Re: MK5 GTI Creaking Sound After Revs
« Reply #1 on: August 22, 2024, 07:48:16 am »
Might be the classic fuel pipe rattle.
They could of got disturbed after the impact.
Are you sure it is not coming from the engine, as it also sounds like a cam chain rattle?
Mike
South Coast
Offline ZoliWorks
« Reply #2 on: August 22, 2024, 12:47:24 pm »
You could start with the dogbone bushings. Mine were shredded and this is what they sounded like
Other than that, I've also had rattling coming from the downpipe fork. It was slightly bent, not sitting flush in it's rubber sockets and vibrating or touching the subframe. This only happened during/after revs and when cold starting.
Or if neither of these are the culprit, then could be the fuel lines.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
