Author Topic: Wipers not turning off after ignition lock housing replacement  (Read 2004 times)
Offline Jd3n
  • Newbie
Hello,
I recently had to replace the ignition lock housing on my car. Upon putting everything back together, I am noticing the front wipers will not turn off, no matter what position the stalk is on.
The horn and steering wheel controls for the radio are functional, which indicate it is likely not the clock spring. I have had the whole assembly on and off a few times now to double check things. Here are some codes on OBD2 I get, hopefully it can help:
So the first:
OBDeleven vehicle history log
Date: 2024-08-25 13:57:02
Full scan
   Control Units: 17
   Fault count: 10
   Control Units:
      08 Air Conditioning
      Faults:
         No trouble codes found
      03 Brakes
      Faults:
      02 Transmission
      Faults:
      25 Immobilizer
      Faults:
      17 Dashboard
      Faults:
      42 Driver Door
      Faults:
      52 Passenger Door
      Faults:
      62 Rear Left Door
      Faults:
      72 Rear Right Door
      Faults:
      09 Central Electrics
      Faults:
            00156 - Activation for windshield washer pump
            Intermittent
            02398 - Activation for rear window washer pump
            Intermittent
      01 Engine
      Faults:
            P160200 - Power supply terminal 30
         Voltage too low
            static
      46 Comfort System
      Faults:
            01134 - Alarm horn
            static
      47 Sound System
      Faults:
            00876 - Left rear treble speaker
            static
            00877 - Right rear treble speaker
            static
      15 Airbag
      Faults:
            00588 - Driver side airbag igniter
            Intermittent
      16 Steering Column
      Faults:
            01426 - Control unit in steering wheel
            Intermittent
      19 Gateway
      Faults:
            01304 - Radio
            Intermittent
      44 Steering Assistance
      Faults:
            00778 - Steering angle sensor
            static
And then I cleared those, to see what would persist, and got this:
Date: 2024-08-25 13:57:41
Full scan
   Control Units: 17
   Fault count: 4
   Control Units:
      01 Engine
      Faults:
      25 Immobilizer
      Faults:
      17 Dashboard
      Faults:
      02 Transmission
      Faults:
      15 Airbag
      Faults:
      16 Steering Column
      Faults:
      52 Passenger Door
      Faults:
      03 Brakes
      Faults:
      08 Air Conditioning
      Faults:
      42 Driver Door
      Faults:
      19 Gateway
      Faults:
      62 Rear Left Door
      Faults:
      Faults:
      72 Rear Right Door
      Faults:
      46 Comfort System
      Faults:
            01134 - Alarm horn
            static
      Faults:
            static
      47 Sound System
      Faults:
            static
            Intermittent
