September 19, 2024, 05:09:10 pm
All Things Mk5
Mk5 General Area
N75 replacement due to age and miles?
Topic: N75 replacement due to age and miles? (Read 265 times)
mjmallia
Won't Shut up.
-Given: 2
-Receive: 50
September 16, 2024, 09:34:28 am »
Well the old girl will be turning 20 next year and making a small refresh list of things I have left to do, as done a lot over the years to it
Is it worth getting a fresh N75 due to the age of the car and over 100K miles, as that valve is continuously working away!
Everything appears to be working fine at the moment......call it preventative maintenance which is what I have been doing a lot of recently on it.
Last Edit: September 16, 2024, 03:10:02 pm by mjmallia
Mike
South Coast
S3 8L ---- Golf Mk4 GT TDI ---- Lupo GTI ---- A4 B6 Sline ----
Golf Mk5 GTI
ZoliWorks
Always Involved
-Given: 3
-Receive: 10
Re: N75 replacement due to age and miles?
Reply #1 on:
September 16, 2024, 09:48:24 pm »
At least for the K04, the actuator is what gives out sooner. Honestly you should be fine, but at the same time, if you wanna be safe, I'd replace both the valve and actuator.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
mjmallia
Won't Shut up.
-Given: 2
-Receive: 50
Reply #2 on:
September 17, 2024, 09:33:35 am »
I did a K04 DV relocation on my K03 quite a while ago now, so that is all fresh already.
Not sure about the actuator, so will need to read up on that one.
Mike
South Coast
Golf Mk5 GTI
ZoliWorks
Always Involved
-Given: 3
-Receive: 10
Reply #3 on:
September 17, 2024, 09:55:18 am »
One of the tuners I spoke to who also does turbo rebuilds said that the actuator should be replaced every 100k km because the membrane can develop cracks or the whole mechanism can start sticking and not moving as it should, which changes the cracking pressure of the wastegate and overall impacts the boost control. But, my K04 has well over 260k km on it and I can't say I notice any of the above.
mjmallia
Won't Shut up.
-Given: 2
-Receive: 50
Reply #4 on:
September 17, 2024, 10:05:32 am »
Mike
South Coast
Golf Mk5 GTI
All Things Mk5
Mk5 General Area
