November 22, 2024, 11:08:03 pm
All Things Mk5
Mk5 General Area
Quick question about smoke testing
Topic: Quick question about smoke testing (Read 383 times)
MKVASMR
Taking part
-Given: 0
-Receive: 0
My Ride:
October 12, 2024, 04:20:58 pm »
Hi guys. I wanted to ask you if it’s normal when performing a smoke test with the machine connected to the intake to have smoke buildup under the valve cover? I did it yesterday and there was a lot of smoke when I opened the oil fill cap.
GVK
Won't Shut up.
-Given: 1
-Receive: 67
Re: Quick question about smoke testing
Reply #1 on:
October 12, 2024, 04:43:48 pm »
It will go through the pcv i expect into the head.
Scirocco TDI GT
https://www.facebook.com/groups/gvkmotorsport
MKVASMR
Taking part
-Given: 0
-Receive: 0
My Ride:
Reply #2 on:
October 12, 2024, 04:47:31 pm »
So I’m guessing that’s normal. Next question. Where to hook up the smoker to test the vacuum lines. My brakes feel quite stiff although the car brakes ok.
GVK
Won't Shut up.
-Given: 1
-Receive: 67
Reply #3 on:
October 12, 2024, 04:56:15 pm »
Never used a smoke tester myself but I would check you vac booster pipe that goes from vac pump on the end of the head to the servo, they're plastic and can snap.
Scirocco TDI GT
All Things Mk5
Mk5 General Area
