Author Topic: Which are the right injectors  (Read 6174 times)
Offline Numero9
« on: December 01, 2024, 05:29:07 pm »
2008 standard GTI, BWA engine
Had a right hassle with injectors and in need of some guidance. Misfire on cylinder 3 can after investigating decided to change the injector. OEM number on the injectors is 06F906036A.
GSF injector is for the CAWB engine and when I looked at it the o-ring which seals into the fuel rail was green. (https://www.gsfcarparts.com/185vg0570)
Eurocarparts image looks right however the part I got was the same as GSF, green o-ring (https://www.eurocarparts.com/p/bosch-injector-431441870#bl-ecp-204-nf)
The wrong one supplied had a Bosch number of 26150001 but the right one in the image has Bosch number of 026150076.
Am I correct to think that the one from GSF with the green o-ring is incorrect and I need to find the right one? OEM is a fortune so that rules out going there. Ideally I'd rather just replace the one which is gone but if I can find them cheap enough happy to replace them all and keep the others as backup.
Secondly, I ordered 1x seal repair kit but just read that as I have removed the manifold & disturbed them all I need to replace the seals on all of them. I have ordered another 2 seal kits as the new injector I buy will already have the seals however when removing the manifold I see that the clips are plastic and cracked so want to replace them with the metal clips but can't seem to find them if anybody has a link or part number that can help?
Offline ZoliWorks
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
Offline Numero9
Re: Which are the right injectors
« Reply #2 on: December 01, 2024, 09:21:03 pm »
Injector seal repair kit https://www.bar-tek.com/tfsi-fsi-einspritzventile-reperaturkit?navigationId=30aab211ab074b36b4e15b1ac221f91e&no-aggregations=1&order=standard&p=1
Somebody sent me this which I think will work and comes with all of the clips: https://www.autodoc.co.uk/elring/16598744
Now just stuck on which is the right injector to buy, although I think this should work: https://www.autodoc.co.uk/bosch/657292#injector
« Last Edit: December 01, 2024, 09:27:00 pm by Numero9 »
Offline Numero9
« Reply #3 on: December 02, 2024, 08:27:34 pm »
anybody?
Offline Bagus
« Reply #4 on: December 31, 2024, 10:54:25 pm »
The injectors for the std GTI is 06F906036A. The price from Autodoc isn`t too bad. When I was looking last year I couldn`t find them cheaper than £280 each. Just make sure you don't buy them from ebay as too many dodgy sellers with fake injectors.
Seal kit 06D998907
« Last Edit: December 31, 2024, 11:52:22 pm by Bagus »
Offline hcmzah
« Reply #5 on: January 10, 2025, 04:34:32 pm »
If you contact Rtech they have some refurbished injectors for £100, cleaned, tested and they can send a video. Fixed my misfire
