Author Topic: Car sputters with MAF plugged in. When unplugged it drives perfect. Why?  (Read 3880 times)
Offline Reeceyy
Hey guys,
I've got an issue where the car drives amazingly well when the MAF is unplugged. Boosting really well, accelerating well, all the power is there, revving well, idles fine, drives exactly how it should, but when I plug the MAF sensor, around 5000rpm under hard acceleration is starts hesitating as if it were bouncing on the rev limiter. It's frustrating! I cleaned it the other day too. No difference! Does anyone know why this is happening?
Thanks I'm advance
« Last Edit: December 05, 2024, 06:15:11 am by Reeceyy »
Offline ZoliWorks
Re: Car sputters with MAF plugged in. When unplugged it drives perfect. Why?
« Reply #1 on: December 05, 2024, 04:25:54 am »
Could be a faulty maf. I'd log lambda correction/lambda control. That tells you if the car is running rich or lean, which could explain the issues at 5k revs. Mine is running so lean it's cutting power at or above 5k due to stock injectors and high boost. If it's cold outside, it starts as low as 4k.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
Offline mjmallia
« Reply #2 on: December 05, 2024, 08:09:29 am »
Most prob the MAF as said, as it sounds like it is failing/failed and unable to read the air flow correctly......running rich to be safe
With it unplugged you will be using baseline settings, but will not be getting the best out the engine as it does not know exactly how much air is entering the car to calculate combustion.
Buy genuine for the MAF in my opinion.
Mike
South Coast
