Author Topic: Changing Coolant Pipe-Will I need to drain the system?  (Read 208 times)
Offline Numero9
« on: December 16, 2024, 05:13:55 pm »
Noticed some damaged to the coolant hose which feeds the top of the radiator passenger side, I've got a replacement on order but wondering as it's the top if I can get away with not draining the system and just change it? It is below the reservoir so I assume yes but ideally want to avoid getting the car back on ramps and having to rebleed the system but will do it I have to.
Side question what coolant do people use?
Image of the hose for refetence
Offline MKVASMR
  • My Ride: 2008 GTI
Re: Changing Coolant Pipe-Will I need to drain the system?
« Reply #1 on: December 16, 2024, 07:02:44 pm »
You can but you will still lose coolant. The whole head is full with it and I think some from the cabin heater will come out aswell. Do yourself a favor and change the flange aswell with a metal one. They are nutorious for snapping when you expect it the least 😁
Offline ZoliWorks
« Reply #2 on: Yesterday at 05:59:42 am »
You can probably change that one without losing too much coolant. Just refill after.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
Offline Numero9
« Reply #3 on: Yesterday at 10:14:47 am »
When you say flange what do you mean? Part number or pic?
