Author Topic: My car engine is making a screeching noise  (Read 34 times)
Offline ramiroelliot
  • Newbie
« on: December 27, 2024, 02:33:32 am »
Hi, I've had this problem for a while now and I'm starting to worry that it's going to cause a bigger problem if any of the belts or bearings or whatever is causing the noise completely fails.
I can't figure out what it is and it seems to be coming from somewhere deeper inside the engine but on the left side so I can't diagnose exactly where. The noise is also related to the rpm of the car, so the more it revs the more frequent the squeal. It also goes away completely when the car is warm enough (usually when the engine reaches the ideal temperature for WOT)
so if anyone has had this problem please give me some advice. Thanks!
