Author Topic: Temp Flactuating when it hits 70  (Read 1818 times)
Offline moskii00
  • Newbie
« on: January 05, 2025, 05:45:41 pm »
Hi,
My temp is still fluctuating one it hits 70 and never reaches 90 for awhile, it keeps going under 70 and above by a little. I have so far changed the inline stat and the temp sensor and the temp is still fluctuating, should i go for the main stat next?
Offline ZoliWorks
  • -Receive: 31
Re: Temp Flactuating when it hits 70
« Reply #1 on: January 16, 2025, 07:20:21 am »
Always start with the main thermostat. That's the one that goes bad and is the most responsible for temp issues.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Online mjmallia
  • -Receive: 59
« Reply #2 on: January 16, 2025, 08:11:56 am »
As mentioned the main stat should be changed.  With the alternator out and undertray out.........some patience, jigging, unplugging and time, it can be done on the drive for the cost of parts.
Remember to order the O-ring for a pipe seal, as it is not included and do not want to have leaks after all the faff of fitting it.....red arrow
Good guide here:
https://pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/31-WATER-Replacing_Your_Thermostat/31-WATER-Replacing_Your_Thermostat.htm
Mike
South Coast
Offline PorkPieBandit
« Reply #3 on: January 18, 2025, 11:06:11 am »
I did my main thermostat recently and found that pelican guide really useful. This video is handy too
I'd also really recommend some flexible hose clamp pliers, I bought some especially and I would have struggled without. Not the exact set I got but this type of thing - https://www.amazon.co.uk/Dapetz%C2%AE-Flexible-Reach-Clamp-Pliers/dp/B08HQS9552/ref=asc_df_B08HQS9552?mcid=448ae44ac9dd3013b3c5db9c8a8aa842&tag=googshopuk-21&linkCode=df0&hvadid=697205530764&hvpos=&hvnetw=g&hvrand=5704810594983826337&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9045888&hvtargid=pla-1723050376478&psc=1&gad_source=1
