Author Topic: Misfire when engine cold and at low revs.  (Read 146 times)
Offline nelson1m
« on: January 13, 2025, 11:09:19 pm »
Hi I’ve got a misfire when the engine is cold and idling. It persists when driving slowly in the low gears.
After a while driving it seems to disappear. Had the coils checked all fine.
Had all brand new spark plugs. Was advised to use fortes emissions cleaner. Seemed a little better but still misfiring when idling and in low gears driving slowly.
The car has been asking for “service now” since around mid September but couldn’t afford around Christmas. Booked in for a full service on the 21st of this month.
Can anyone help? Mk5 07 on 98k
Offline mjmallia
Re: Misfire when engine cold and at low revs.
« Reply #1 on: Yesterday at 09:10:30 am »
Have you ever done or had an intake valve clean, as they clog with carbon build up......this causes misfires
Checked the cam chain for stretch.....this causes misfires and a lumpy idle?
Checked the cam adjuster for wear and or broken oil rings.......this causes misfires and a lumpy idle depending on which ring broke?
Possible lazy injector issue also
All issues that arise at the 100kish miles on what I assume is a GTI.
I recently worked though my GTI and came across them all except the injectors......time consuming, but okay for a DIY'er
Drives perfectly now and improved with every step........old cars now that need that major servicing with the miles they have on the clock
« Last Edit: Yesterday at 09:12:14 am by mjmallia »
Mike
South Coast
Offline nelson1m
« Reply #2 on: Yesterday at 02:41:27 pm »
That’s great thank you.
I decided to fill up the tank and take it for a good blast!
Woke this morning and turned on the engine…. No misfire. That Fortes emissions cleaner must have worked, fingers crossed!
