Author Topic: Metal Valve Stem  (Read 474 times)
Offline Fas
  • Newbie
Metal Valve Stem
« on: January 16, 2025, 11:34:08 am »
Recently bought my first MK5 GTI (06) as my first daily performance car. Ownership currenlty has been great until finding out I can't buy a metal valve stem, from VW (or anywhere in the UK), for my wheels leaving me with a flat.
Looking at forums i think my wheels are monza I (17" with a lip around the valve). I believe the part I'm looking for is '1K0 601 361 B' or maybe '1K0 601 361'.
If anyone has a recommeneded/trusted supplier please let me know. Or if I am getting the wrong part
Re: Metal Valve Stem
« Reply #1 on: January 18, 2025, 07:49:38 pm »
are you sure you have 17" rims as I thought only the Monza 18" rims used that valve.
The part number for the 18" Monza rim is  1K0 601 361
« Reply #2 on: January 18, 2025, 10:45:37 pm »
Offline mjmallia
« Reply #3 on: January 20, 2025, 08:16:08 am »
The early 17" GTI wheels definitely have metal valves, as I have a set of them in the garage.
They look like the ones in the link above, but the seals can be changed......no idea of the seal specs, so you would need to measure a removed one
« Last Edit: January 20, 2025, 08:20:04 am by mjmallia »
Mike
South Coast
Offline Octoparrot
  • -Receive: 102
« Reply #4 on: January 20, 2025, 10:42:12 am »
It does seem confusing, I ended up replacing my metal valved wheels for later rubber versions. This thread may help: https://www.mk5golfgti.co.uk/forum/index.php/topic,72725.0.html
Offline mjmallia
« Reply #5 on: January 20, 2025, 02:58:43 pm »
Depends if you have the early hollow BBS versions or the later solid RONAL versions
Mike
South Coast
