Author Topic: Fan always on even when car hasn't been used  (Read 326 times)
Offline Tinytim
« on: January 27, 2025, 06:56:50 pm »
Bizarre issue has occurred.
I've fitted some factory xenons. Car originally came with halogens.
I've coded it in vcds to tell it xenons without shutter.
Now the fan keeps running constantly which is flattening the battery.
Anyone any idea what could be causing this?
Tim.
Offline mjmallia
Re: Fan always on even when car hasn't been used
« Reply #1 on: January 28, 2025, 09:23:40 am »
Sure you did not knock the sensor or the wires when fitting the headlights.
Mike
South Coast
Offline Tinytim
« Reply #2 on: January 28, 2025, 10:01:17 am »
Pretty certain that's not the case.
I was concerned adding the Xenons with cable adapters had caused some sort of voltage issue.
