Author Topic: Suspension Recommendation  (Read 6196 times)
Offline Smithy1222
« on: March 07, 2025, 04:40:50 pm »
Hi all,
I need to replace my suspension due to a blown shock, but annoyingly due to insurance I cant get an aftermarket suspension kit as it just adds too much to my premium. Where do people recommend getting original OEM suspension from? Are the usual GSF / Euro Car Parts the best or are there any good websites which sell a complete kit? I am struggling to find out the GTI spring spec as I dont want to accidentally install base model springs!
Offline Jons1001
  • -Given: 22
Re: Suspension Recommendation
« Reply #1 on: March 07, 2025, 05:21:47 pm »
Hi, I have this saved in my phone as I was going to do similar and replace my suspension with oem parts.
Front shock Sachs 317579
Rear shock Sachs 310950
Front spring Sachs 993167
Rear spring Sachs 994632
Top mounts - Lemforder
Ball joints - Lemforder
S3 control arm bushes (Instead of anti lift kit)
Sorry don’t have part numbers for some of it. I was looking on Autodoc for the springs and shocks and they seemed to be priced reasonably.
Offline MKVASMR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pq62a9m5mgca5ir7fq4dqo9m1j&/topic,134365.msg1165175.html#msg1165175
« Reply #2 on: March 07, 2025, 05:27:36 pm »
The rear springs may differ depending on if you have a trailor coupler.
Offline ZoliWorks
« Reply #3 on: March 08, 2025, 06:01:06 pm »
Another option would be going with Bilstein B4 sport OEM replacement. Apparently about 5-10% stiffer than OEM and it's a nice little upgrade. Cant speak for Sachs shocks cause I went with KYB at first but it might as well have welded the old ones and would have still been more comfortable..
Can recommend the Bilstein's a lot tho. Have had them for the past 10k km and they are quite comfortable
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline Lewo
« Reply #4 on: March 09, 2025, 10:01:17 am »
Another b4 recommendation here.
look at sellers on Ebay & Autodoc.  :happy2:
Offline lazy
« Reply #5 on: March 09, 2025, 11:27:15 am »
https://www.awesomegti.com/temp/koni-special-active-damper-kit-golf-mk5/
I was thinking about these when the time comes, just to try and smooth out the ride a little. When I'm doing my daily commute and I'm tired small bumps can be really annoying.
Offline Scott1974T
  • Newbie
« Reply #6 on: March 12, 2025, 02:42:21 pm »
Does anyone know what the spec is for the Bilstein B3 OE replacement springs? On AutoDoc it comes up with these for my 2007 GTI as a replacement fit and they are only £22.14 each which seems a bargain. This is for the rear springs. It notes them as for 'standard suspension without a trailer hitch'. Does anyone know if these are the same dimensions as what would be on the car or of these are for standard model Golfs? I'm wary of AutoDoc as I've had issues with incorrect parts before with them. From what I can gather online the OEM GTI rear springs should be about 299/300mm long but there is no info about this on the AutoDoc site. I went on the Bilstein website to check and they have them for the GTI but reference it as a standard chassis so I'm assuming this would be OEM? They're part number is a different one from that on AutoDoc. Again, no technical info on Bilstein's site as to the actual dimensions. Bilstein direct are only a few quid more than AutoDocs price. Thanks if anyone can help.
