Author Topic: What is this split hose?  (Read 115 times)
Offline Kakashicoc2015
  • Newbie
« on: Yesterday at 02:51:46 pm »
Can anyone kindly tell me what this split hose is in my engine bay? On the right side. Is this a major concern?
I don't know much about cars and always wanted a golf gti. There seems to be a minor oil leak too.
Offline lazy
Re: What is this split hose?
« Reply #1 on: Yesterday at 03:40:01 pm »
That's not hose, it's a cover around the wiring loom so nothing to worry about. If you can clean the area with brake cleaner hopefully you will be able to see where the leak is coming from. It's possibly coming from the vac pump which is directly above the electrical plug in your picture. Apparently very common, mine is leaking another job I need to do.
Offline ZoliWorks
  • -Receive: 20
« Reply #2 on: Yesterday at 07:23:34 pm »
Get that vacuum pump serviced too (the parts above the wiring loom that's leaking). Mine was also leaking but I paid it no mind. it ended up failing while driving and almost couldn't stop.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | S3 Injectors | Vis Motorsport 175 bar HPFP | 350hp 480nm
Offline hcmzah
« Reply #3 on: Today at 12:57:56 am »
Yes it's most likely the brake vacuum pump. For me it was leaking and made a hole in the casing. I replaced my seals just yesterday.
As far as I know, you can't buy OEM seals and you normally have to replace the whole unit. However if you look on ebay you can find some seals.
Here's a video I followed:
