Author Topic: Noise Diagnosis (with video)  (Read 4028 times)
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« on: April 09, 2010, 12:20:43 pm »
Hi guys, I was hoping someone might be able to tell me what this noise is, before I take my car down to the local VW garage.
It has became quite persistent over the last few weeks. In the video the car's engine is up to temperature having been driven approximately 10 miles in 30 - 40mph traffic. The car is an 06 GTi, and has covered nearly 32K miles.
Thanks in advance for any help you can give me.
Offline Garth
    • My Build thread
Re: Noise Diagnosis (with video)
« Reply #1 on: April 09, 2010, 12:23:13 pm »
Definately a family of mice in there somewhere!
Offline titchy
« Reply #2 on: April 09, 2010, 12:27:44 pm »
sounds like a belt tensioner try taking the drive belt off see if it goes
  • -Given: 32
  • -Receive: 78
« Reply #3 on: April 09, 2010, 01:21:24 pm »
Haha, I'm no mechanic, I just don't want VW charging me a fortune if it's something relatively simple.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #4 on: April 09, 2010, 01:58:56 pm »
In my non expert opinion it sounds like a pulley wheel, or a slipping belt. I certainly wouldnt want to be taking any belts off and then starting the engine, but Ive never played with the engine in any great details.  Hopefully an experienced mechanic will be alone with an expert opinion soon.
I would hope a VW garage would be able to have a mechanic come out and listen to give an initial diagnosis of the problem if asked nicely, especially if they serviced or sold you the car.
BUMP
Offline Russ_leeds
« Reply #5 on: April 09, 2010, 04:35:50 pm »
i had a similar noise, no where near as bad as that tho, it turned out to be the cambelt tensioner, and had cambelt and such done under warranty
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline JLCoad
« Reply #6 on: April 09, 2010, 04:44:03 pm »
Ditto Russ
Offline gazbutS3
« Reply #7 on: April 09, 2010, 04:47:24 pm »
cambelt tensioner for me :happy2: not un-common
  • -Given: 32
  • -Receive: 78
« Reply #8 on: April 09, 2010, 05:32:38 pm »
So new cambelt? I think the VW price is £285 and the car has just turned 4 years old, the time they recommend a change.
Saint Steve
« Reply #9 on: April 09, 2010, 05:33:03 pm »
As above and as on GolfGTi thread chap :innocent:
Offline Neimad
« Reply #10 on: April 09, 2010, 07:14:27 pm »
Mine does this too, but it stops after the car has warmed up.
On one visit to my dealer I mentioned it to them and they actually fixed it... although their fix lasted only 24 hours.  At the time they told me that something was catching on the engine cover.
The next time I had my car in I re-raised the issue, told them that they'd fixed it previously and asked them to look in to it again.  This time they professed they couldn't hear anything and couldn't find the problem at all.  Then they said that if I wanted they would keep the car overnight and look at it again in the morning if I wanted (due to me telling them it was related to engine temperature) but since the dealer I use is near my office, which is 40 miles from my house, and they didn't have any spare courtesy cars it never happened.
Since then my car has gone out of warranty so I guess I'll be paying for that out of my own pocket, although since my car is about due it's cambelt change anyway I guess it will get sorted one way or the other...
  • -Given: 32
  • -Receive: 78
« Reply #11 on: April 09, 2010, 08:02:05 pm »
Cheers for all your responses guys. The car is booked in for a cambelt change next Friday.
Incidentally, are there any other items than need attention around the 4 year mark? How long does the diverter valve last?
Offline Matt23
« Reply #12 on: April 09, 2010, 08:15:39 pm »
I too get this noise but only on start up from cold and soon disappears should i be worried and get it changed ?
If your car is a dsg the gearbox needs oil and filter change. Other members have had the water pump done too when having the cambelt sorted as its in the same area and cambelt needs to be removed to get at the water pump i think.
  • -Given: 32
  • -Receive: 78
« Reply #13 on: April 12, 2010, 09:42:57 pm »
A few other people have suggested it might be the aux belt that is causing the noise.
Is this it pictured? Because that is exactly where the squeaking noise is coming from.
Offline PDT
  • -Receive: 142
« Reply #14 on: April 12, 2010, 09:50:17 pm »
Sounds like the Alternator (aux) belt tensioner. They quieten down when they warm up as the grease (they are a sealed for life bearing) warms and gets a bit thinner so it lubricates a bit better.
The tensioner is directly at 10 o'clock in the pic you have posted. I have seen the cambelt tensioner make a similar noise but my guess is the aux belt
