Author Topic: Little help to put my mind at ease please - DV replacement  (Read 22280 times)
Offline nc35
  • -Given: 40
« on: April 11, 2010, 05:16:47 pm »
Hi All
Well spent a good afternoon on the car doing loads of work I have been meaning to do for the past few months.
The main one being replacing the original DV.
Well on the left is the original type "B" and the new type "D" on the right.  Is this right or is there bits missing from the original?  :scared:
The second picture is just to show I haven't left anything behind!!!!
The new DV went on without a hitch, and the engine has started, but throughout the afternoon I have become more and more paranoid.
Can someone please put my mind at rest before I take it for a test drive.
Thanks in anticipation.
Lee
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Offline cmdrfire
    • Commander Fire - my blog
Re: Little help to put my mind at ease please - DV replacement
« Reply #1 on: April 11, 2010, 05:36:34 pm »
The "D" type replacement looks fine. Looks the the top of the "B" type is missing.
« Reply #2 on: April 11, 2010, 05:40:49 pm »
i would be pulling the new one off asap as something has come off the old one  :surprised:
Offline nc35
  • -Given: 40
« Reply #3 on: April 11, 2010, 05:48:16 pm »
I have had a good look in the "hole" where the old one came from, before fitting the new one.  There is deffo nothing left in there.
This is my worry that there are bits floating around in there that shouldn't be.
Going to nip out and have one more look on the floor under the car etc.
At the moment I think the bit has been missing for some time (possibly since new)
Would I have known?  Never driven another GTI to compare.
No Golf anymore.
Thank You Everyone.
Offline snapey
« Reply #5 on: April 11, 2010, 05:53:39 pm »
Have a look on the back of the wishbone to see if it's dropped off and sitting there. I constantly dropped the allen key and it always ended up there.
Luke.
If you have to ask why, you'll never understand.
Offline nc35
  • -Given: 40
« Reply #6 on: April 11, 2010, 05:58:27 pm »
Yep just had a look, no sign of it anywhere  :surprised:
Thanks for all your replies.
Can't believe it's been missing since the factory.
No Golf anymore.
Thank You Everyone.
Offline winrya
« Reply #7 on: April 11, 2010, 06:01:15 pm »
I'd imagine it is going to drive like a different car if it really has always been missing :grin:
Offline Garth
    • My Build thread
« Reply #8 on: April 11, 2010, 06:02:35 pm »
It can't have been missing from the factory or your turbo would not have worked at all!
The end must have fallen off when you removed the old dv. As mentioned above, I kept dropping my allen key and could I buggery find it again. It took ages to find it with a magnet on an extendable pole. I though the cay had eaten the allen key!
Offline nc35
  • -Given: 40
« Reply #9 on: April 11, 2010, 06:15:01 pm »
OK
Been under the car again. No sign of it anywhere.  I think I would have found it.
I am also 99% sure that it wasn't there when I took the old off. It wasn't a case of dropping the old DV I had to ease it off. The inside of the old DV even had traces of oil ,pics taken after I cleaned the oil off as I was looking to see if anything was broken.
Are you sure the turbo wouldn't have worked? Thought the dv helped it spin up easier from lower revs?
Really weird.
Think I will take it for a test run tonight before the work run in the morning.
No Golf anymore.
Thank You Everyone.
Chris
« Reply #10 on: April 11, 2010, 06:17:19 pm »
What was the reason for changing from a B to a D ?
Offline nc35
  • -Given: 40
« Reply #11 on: April 11, 2010, 06:19:36 pm »
Reading this forum  :signLOL:
keep reading the other versions fail.
Don't know what symptoms to look for.
No Golf anymore.
Thank You Everyone.
Offline Garth
    • My Build thread
« Reply #12 on: April 11, 2010, 06:22:31 pm »
Really weird.
If there's no dv (or a broken one), the turbo pressue will be venting and therefore the turbo will have zero boost (hence not working). You would hear a constant hissing as the boost pressure is always being released like it should when you lift off the accelerator.
The B is VERY weak and fails (mine did). There is a rubber diaphragm on the B version that splits after a while and you lose boost pressure. The D version uses a piston and is much stronger.
 :drinking:
Offline nc35
  • -Given: 40
« Reply #13 on: April 11, 2010, 06:29:40 pm »
Well now you mention it - "constant hissing", Yes, thought that was the Turbo spinning up...
And no "push in the back" when the turbo comes in.  Just thought the engine was really smooth for a turbo.  Used to get a real kick when the KN-TT came on song, but kind of expected that.
No Golf anymore.
Thank You Everyone.
Offline nc35
  • -Given: 40
« Reply #14 on: April 11, 2010, 07:11:19 pm »
Test drive over.
Car transformed.
You can now tell the car has a turbo. Can also understand why you guys fit WALK kits.
Truly amazed by the difference.  Thought it was quick before.
Just wonder what happened to the rest of it.
No Golf anymore.
Thank You Everyone.
