November 27, 2024, 04:28:16 pm
All Things Mk5
How to Guides / Troubleshooting
Gear gator/knob removal
Topic: Gear gator/knob removal (Read 2130 times)
Murray86
Taking part
-Given: 0
-Receive: 1
April 12, 2010, 06:50:26 pm »
Folks,
I can't see a guide about removing gear gator and know for 6spd manual. I have the golfball gear knob on order to looking for a heads up from someone who has done it. Just dont want to damage anything or scratch anything while removing old one.
Murray
GT TDI 140
Gene Hunt
Just look at my post count
-Given: 59
-Receive: 61
Re: Gear gator/knob removal
Reply #1 on:
April 13, 2010, 12:03:40 pm »
Easy mate.1. Put car in to 2nd or 4th gear.2.At the front edge of the gaitor (near the t.c.s) feel under the gaitor & gently pull upwards to release the clips, work the gaitor all the way round with you'r fingers to release the clips.3.Pull the gaitor upwards so it goes in side out & you will see a metal band/clip type thing.Beore removing this try to pull the gear knob off(mine came straight off) if it won't remove the band & then pull the knob off.
Fitting is easy just place the new knob over the gear stick & give a good hard press down & it will go straight on. Work gaitor round consol & press clips in to place.
Dead easy job & should only take a few mins mine did.
andrewparker
-Given: 32
-Receive: 78
Reply #2 on:
April 13, 2010, 12:15:49 pm »
I tried removing it without snipping the clip and it won't budge. The clip is very tight.
Will need to wait until I get home to my tools
big al
-Given: 27
-Receive: 93
Reply #3 on:
April 13, 2010, 12:45:37 pm »
I did not even remove the clips on mine.
Just pull up the gaitor, and then grip the gearstick and keep twisting, it came off in about 10 seconds with mine, as I could not get the clip off mine!
Gene Hunt
-Given: 59
-Receive: 61
Reply #4 on:
April 13, 2010, 01:06:49 pm »
........same here.Just give it a good old pull
.lol
Murray86
Taking part
-Given: 0
-Receive: 1
Reply #5 on:
April 15, 2010, 06:51:11 pm »
Thanks guys got it sorted. The new golfball gearknob is on and looks great, well chuffed.
GT TDI 140
All Things Mk5
