Author Topic: Coil pack gone!  (Read 10698 times)
Offline micky 32
Re: Coil pack gone!
« Reply #30 on: April 14, 2010, 09:57:18 pm »
Do you power wash the engine? I had power washed my engine and later i found water like you did so i put it down to that.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Re: Coil pack gone!
« Reply #31 on: April 14, 2010, 10:41:08 pm »
Never ever as Ive seen what can happen when water ingresses into the coilpack loom  :surprised:
I have no engine cover but bizzarre how its just in one cylinder  :confused:
Offline micky 32
Re: Coil pack gone!
« Reply #32 on: April 14, 2010, 10:54:21 pm »
Didn't DanGB have a problem like this? It's very strange how water gets in there under the bonnet in a hot engine :scared:
Re: Coil pack gone!
« Reply #33 on: April 14, 2010, 11:14:21 pm »
Yep, melted all his coilpack connector and damaged the loom.  The sound insulator used to droop so i removed it, it seamed to retain water so maybe that stops it from getting on the engine.
It drooped looked messy and scorched my engine cover.  perhaps ill try a new one and try new clips.
The only other thing i can think of is if the sealing rubber on the coilpack isnt doing its job
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: Coil pack gone!
« Reply #34 on: April 14, 2010, 11:56:11 pm »
I get water in my engine bay, when I lift the bonnet it drips right onto the coilpack area.Think the bonnet insulation did stop this from happeneing.
Offline DaveyCupra
Re: Coil pack gone!
« Reply #35 on: April 15, 2010, 09:44:33 am »
Mike, Poverty;
Guys, I also get water in my engine bay as I have the sound insulation removed and when I bought the car I changed the plugs and cylinder number 4 was full of water also  :fighting: I phoned the dealer I had bought the car off and it turns out they had pressure washed the engine before I went to look at the car  :surprised:
So I used an air line to blow out the water in cylinder 4, cleaned the Coil pack with WD40 and Electrical Contact Cleaner and refitted everything been fine since.
I do periodically check the coil packs by removing them and seeing if there is any water building up around the spark plugs again but nothing since thankfully.
When I remove the coilpacks I clean up inside them with Electrical Contact Cleaner and cotton swabs (like the ones for your ears lol) then spary a light coating of WD40 on the outside of them, let them dry off and refit them. I don't know if this helps them or not though.
Re: Coil pack gone!
« Reply #36 on: April 15, 2010, 09:51:25 am »
Will give that a go, ta mate  :happy2:
Re: Coil pack gone!
« Reply #37 on: April 16, 2010, 06:19:36 pm »
She's poorly :(
misfiring. Coilpack 4 was dirty and wet.  Steve @ statlers put me in a new one and seamed ok.  Still misfiring in hi map under load :'(
what to do. Was fine till I swapped for the irridiums
Re: Coil pack gone!
« Reply #38 on: April 20, 2010, 02:54:58 pm »
What is the ed30 / cupra / s3 coilpack part number?
Cheers!
