Author Topic: arm rest  (Read 5054 times)
Offline 4d 2006
arm rest
« on: April 13, 2010, 06:39:43 pm »
Hi fellas been thinking of getting an arm rest for my golf but was wondering if i can buy the side and back plastics for it as these are damaged on the one ive seen. anyone know the price if this is possible.
Thanks guys  :happy2:
cameluk
Re: arm rest
« Reply #1 on: April 18, 2010, 10:09:45 pm »
Assuming you mean the bottom part (2 and 3 in this drawing)
Part 2  - 1K0863323Q 71N (antracite) CD changer version £32
part 2  - 1K0863323M 71N (antracite) non CD changer version £32
Part 3  - 1K0863289 71N (antracite) £49
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
Re: arm rest
« Reply #2 on: April 18, 2010, 11:18:02 pm »
Mine was from ebay mate. £210 delivered I think, from a VW garage up north that sells stuff on there. All OEM and everything was included. Retrofit is relatively easy and if you google/search on here, you'll find a PDF guide. Alternatively, PM me your email and I'll send it across  :smiley:
I think it's not too much more from VW but iirc, it is more expensive overall by about £40 buying them individually.
Pete
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
Re: arm rest
« Reply #3 on: April 19, 2010, 02:11:53 am »
Does anyone know if this part has the outside connector for the Aux socket or is it a case of cutting it out yourself?
Cheers,
Wayne
Offline Lyons
  • -Given: 18
Re: arm rest
« Reply #4 on: April 19, 2010, 07:43:23 am »
Would you have a price for part 7?
Also, when i fitted my second hand armrest it is a lot looser than that in my wifes Match, its nowhere near as stable when i lean on it.
From what i can remember all screws and parts were fitted, but it came with the majority assembled.
Any idea what could be wrong?
cameluk
Re: arm rest
« Reply #5 on: April 19, 2010, 04:55:57 pm »
part 7 is around £32
The bracket comes preassembled, so I'm not sure who it could become loose
cameluk
Re: arm rest
« Reply #6 on: April 19, 2010, 05:02:45 pm »
Your right, it comes with the hole for the aux socket
You need to add 5M0035345 (35p) as a blanking cover or 1K0035724B (7.50) for the AUX socket
Offline Moschops
  • -Given: 118
Re: arm rest
« Reply #7 on: April 19, 2010, 05:43:37 pm »
Mr Camel, your a star... :happy2: Now both cars has the Aux socket inside the cubby hole as it has no Ipod or CD changer, so is it a case of just ordering part 2 and the Aux socket and then just swap the cases over and disconnect the inside Aux socket to the new outside connection? Or will I need some more more parts?
Many thanks for your help... :pomppomp:
« Last Edit: April 20, 2010, 03:17:42 pm by Moschops »
Cheers,
Wayne
cameluk
Re: arm rest
« Reply #8 on: April 19, 2010, 09:06:20 pm »
There are two versions of the centre console
1K0863323Q 71N is the version for the cd changer or MDI and has the hole for the aux socket
1K0863323M 71N is the version without the slot for the cd changer/mdi and just has a big bin in it but it doesn't say if this comes with the hole for the aux socket
I hate ETKA at times  :fighting:
Offline Moschops
  • -Given: 118
Re: arm rest
« Reply #9 on: April 19, 2010, 10:24:54 pm »
1K0863323Q 71N is the version for the cd changer or MDI and has the hole for the aux socket This is the one I need then, will I need anything else to perform the swap? Any idea on price?
Many thanks once again for your help... :happy2:
PS...Will I need the storage bin thingy to sit the changer in or does it just sit inside?
« Last Edit: April 19, 2010, 10:29:28 pm by Moschops »
Cheers,
Wayne
