Author Topic: NOOB Question - What goes though this inter-cooler pipe?  (Read 3245 times)
Offline nc35
  • -Given: 40
« on: April 13, 2010, 10:22:51 pm »
Hi All
Hopefully there is no such thing as a stoooopid question.
Got a small weep/leek on this inter-cooler pipe.
Just wondering what is weeping out of it and how can I DIY stop it.
Thanks in advance - sorry for the dumb question.
Lee
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Ifti
Re: NOOB Question - What goes though this inter-cooler pipe?
« Reply #1 on: April 13, 2010, 10:25:30 pm »
Looks like your car is taking a dump.
Actually more like your car has the runs!
Offline S2 Ant
  • -Receive: 21
« Reply #2 on: April 13, 2010, 10:34:55 pm »
I dont know enough about the Mk5 yet to be sure but from past experience of the G40 and G60 supercharged engines, they got oil seeping on the charged pipe between charger and IC. This was generally a sign of failing seals on the charger. If you look inside the pipe it will likely be very oily as well and possibly all through the inlet tract.
Going along those lines it could be your turbo is leaking oil on the inlet side perhaps so could signal turbo oil seals?
What mileage has your car done?
As i say im only guessing from experience on different engines and could be entirely wrong.
Ant
Offline PDT
  • -Receive: 142
« Reply #3 on: April 13, 2010, 10:37:54 pm »
That is totally normal, its oil from the boost system. It always leaks from here as its the lowest point in the boost system. Just remove the clip, remove the seal (clean or replace the seal only 32p) and clean the joint. Then re-assemble.
Easy :smiley:
Offline nc35
  • -Given: 40
« Reply #4 on: April 13, 2010, 10:38:27 pm »
Just done 55K - On the last dealer service it mentioned "OSF intercooler pipe weeping, no further action required".
I thought the inter-cooler, just cooled the compressed gas from the the turbo before its fed back into the engine
No Golf anymore.
Thank You Everyone.
Offline nc35
  • -Given: 40
« Reply #5 on: April 13, 2010, 10:41:29 pm »
Easy :smiley:
Thanks for the info  :happy2:
Always surprises me why stuff like this isn't done as part of the service...
Is it worth getting both the clip and seal from the service dept?  Anyone got part numbers etc?
Thanks again
Lee
No Golf anymore.
Thank You Everyone.
Offline nc35
  • -Given: 40
« Reply #6 on: April 13, 2010, 10:46:24 pm »
Another quick question, would this also cause a slight boost leek in the system?
No Golf anymore.
Thank You Everyone.
Offline PDT
  • -Receive: 142
« Reply #7 on: April 14, 2010, 11:12:22 am »
You are right that the job of the intercooler is to cool the pressurised intake air/boost but you will also get a small amount of oil in the system from the turbo and the recirculated oil vapours from the crankcase/camcover pressure (in general, not a case with all engines) with it being a liquid this will always collect at the lowest point in the system at the intercooler union.
A new clip isnt a must, but its worth getting a seal for the sake of 32p.  The oil is a leak, if oil can get out, so can boost pressure. I clean mine every time its having a service, but its not a concern, its 'normal' on most VAG turbo'd engines, especially diesels. An oil catch can/breather mods can help lower the amount of oil in the boost system. (look at the BSH catch can kit on www.dubtek.co.uk)
Offline nc35
  • -Given: 40
« Reply #8 on: April 14, 2010, 11:19:31 am »
I wish you were a little closer, 'cos you would be getting the car for service.
Small world, when I was at Uni, my m8 lived in Boldon.  His dad was the local fire chief.
Thanks for your input.  Put my mind at rest that the turbo seals are on the way out.  :happy2:
No Golf anymore.
Thank You Everyone.
Offline nc35
  • -Given: 40
« Reply #9 on: April 25, 2010, 07:43:01 am »
Easy :smiley:
Hi PDT
Can I be a bit cheeky. Went to local stealers who are usually quite helpful if you get the right parts guy.
They can't locate the correct seal, so sold me two different sizes on sale or return for £12.
Driving home realised that they must be takining the ........
Any chance I can buy a couple from you? Willingly pay for the parts postage etc and a pint.
Bl@@dy dealers!!!!
No Golf anymore.
Thank You Everyone.
Offline PDT
  • -Receive: 142
« Reply #10 on: April 25, 2010, 10:35:41 pm »
Sure they gave you the right seals  :surprised:
they look like a rubber ring with a ribbed edge and either green or black. I dont keep them in stock but I am at the dealers in the morning picking up this weeks parts orders so  will check the prices for you.
Dave.
Offline nc35
  • -Given: 40
« Reply #11 on: April 25, 2010, 10:45:20 pm »
Hi Dave
Yep green ribbed rubber rings.
If they are cheapo would you mind getting them?  Don't mind if you have to get both sizes too.
Promise to pay you.
Just hate being ripped off.
Will post the part numbers I have innthe morning.
Cheers.
Lee
No Golf anymore.
Thank You Everyone.
Offline nc35
  • -Given: 40
« Reply #12 on: April 26, 2010, 11:23:36 am »
Parts sold:
W3C0 145 117 H - £3.85
W3C0 145 117 F - £5.28
No idea if these prices are realistic or a HUGE markup on 32p
No Golf anymore.
Thank You Everyone.
