Author Topic: Where to get ignition feed for handsfree kit???  (Read 2939 times)
Offline jaffa666
« on: April 17, 2010, 10:33:21 am »
Hey troops in the middle of installing the parrot handsfree kit to the golf, got the centre console out and got everything plugged in but I am left with a red wire coming from the sot adaptor, which I am guessing is the ignition feed.
Where is the easiest place to get an ignition feed and what colour is the wire.
Cheers in advance.
Offline Lyons
  • -Given: 18
Re: Where to get ignition feed for handsfree kit???
« Reply #1 on: April 17, 2010, 01:21:29 pm »
Fusebox.
Have a search on here and uk-mkivs.net, someone has a thread with a photo showing which slot in the fusebox to use.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: April 17, 2010, 01:49:41 pm »
As above, fusebox is the best.  If you buy a VW repair wire you can slot into the back of the fuse box and use a blade fuse to protect the supply.
Stu...
Offline Garth
    • My Build thread
« Reply #3 on: April 17, 2010, 07:32:33 pm »
Or you can take one from the climate controls under the stereo. Much easier to do it this way! If you look at it still connected, if I remember correctly, the far right two wires are switched live and ground.
I used these when I first had my Parrot kit in and it worked perfectly
 :drinking:
Offline icenutter
« Reply #4 on: April 17, 2010, 07:39:52 pm »
Pin 20 on the climate controls worked for me.
Get all your sports nutrition products here; http://www.myprotein.co.uk and use the code MP73153 to get 5% off your first order.
Offline QD MBE
  • -Receive: 102
« Reply #5 on: April 18, 2010, 01:22:15 pm »
Offline jaffa666
« Reply #6 on: April 18, 2010, 03:49:13 pm »
cheers for the response troops, opted for the spade connector into the fuse box. worked a treat, parrot is not up and runnin.
