Author Topic: baffeled sumps ?  (Read 4557 times)
Offline gillm
baffeled sumps ?
« on: April 18, 2010, 09:14:44 pm »
does anyone know if there is 1 out yet ?
west tuned gt28 @ 340hp
Offline gillm
Re: baffeled sumps ?
« Reply #1 on: April 20, 2010, 09:45:46 pm »
bump
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #2 on: April 20, 2010, 10:58:24 pm »
What is it?
Offline jonnyc
  • Herrooooo!
« Reply #3 on: April 21, 2010, 02:23:05 am »
I know of someone developing a dry sump for the 2.0T FSI..
I dont see why you would need one though? None of the race cars run them..
Offline gillm
« Reply #4 on: April 21, 2010, 10:52:45 pm »
not into dry sumping it tbh too much expence . i would like 1 for piece of mind .
Offline tony_danza
  • -Receive: 112
« Reply #5 on: April 21, 2010, 11:14:55 pm »
Have you had the sump off to have a look, it may already have something??
Sideways yo!
Offline gillm
« Reply #6 on: April 21, 2010, 11:26:11 pm »
i must admitt i have not . i was thinking about buying 1 from vag and making my own .
Offline tony_danza
  • -Receive: 112
« Reply #7 on: April 21, 2010, 11:55:50 pm »
It'd be interesting to see inside one, but if VWR aren't using them it may be simply because they're not required?
I can tell you I got no oil lights at 130 around the Rockingham bowl, if that helps?
Sideways yo!
Offline jonnyc
  • Herrooooo!
« Reply #8 on: April 22, 2010, 02:05:28 am »
I agree that it would give peace of mind.. Have you looked into if the Seat Leon Supercopa runs a standard or modified sump?
If not then really I would say dont worry about it.. If they do, then that could well be the easiest way of getting yourself a baffled sump..
My thinking is that you would have to generate a reasonable amount of G for a sustained period to ever have a problem as it is.. Something that wouldnt be possible on road legal tyres..
Offline jabbalad
    • Jabbasport
« Reply #9 on: April 22, 2010, 09:06:44 pm »
the mk2 supercorpa's run a standard sump
There isnt really much room to put any baffles in with how low the balancer/oil pickup assembly hangs into the sump anyway.
I think even for pice of mind you will be fine how it is.... the mk2 supercorpa's have massive ammounts of grip with all the aero and geometry changes, so even with slicks im 99% sure you will be safe   :smiley:
12.7 santapod... soon to be quicker :-)
Candy White Edition 30; Custom KW clubsports, Eibach hollow arbs, Jabba remap, BTB Exhaust, Twintake, Autotech HPFP, Team Dynamics wheels, VWR Big Brakes.
Offline jonnyc
  • Herrooooo!
« Reply #10 on: April 23, 2010, 03:47:45 am »
There you are.. I would say you will be fine mate.. Unless you develop an aerokit that generates more downforce than the Supercopa and run around on something larger than a 9" wide slick  :wink:
Offline jabbalad
    • Jabbasport
« Reply #11 on: April 23, 2010, 09:36:10 am »
The Spanish ones run 9.5" wide softer compound slicks aswell dont they jonny?  :smiley:
Offline jonnyc
  • Herrooooo!
« Reply #12 on: April 24, 2010, 06:24:36 pm »
9.5" rim and a 9" tyre yeah..  :smiley: There fairly quick actually..
  • MUBster DUBster
« Reply #13 on: May 06, 2010, 05:02:02 pm »
What is it?
Google has been  my friend.  Do I take it you guys can get your cars to cause the oil light to come up under hard braking/cornering?
