Author Topic: 3dr / 5dr side skirts - different length?  (Read 5270 times)
Offline holty
  • -Given: 17
« on: April 19, 2010, 10:44:24 am »
I recently got hold of some colour coded side skirts off a 5 dr, when i came to fit them (to my 3dr) yesterday they seemed a little longer (5 mm or so).
Should they be longer or am i just going a little mad?  I no longer have my original 3 door ones to check against!
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: 3dr / 5dr side skirts - different length?
« Reply #1 on: April 19, 2010, 10:46:31 am »
I have 3 door sideskirts on my 5 door, no difference as i see it, just get them fitted  :happy2:
Over the top mod list ;o)
Offline holty
  • -Given: 17
« Reply #2 on: April 19, 2010, 11:13:37 am »
cheers!
Only fitted one yesterday! was a nightmare, had to remove the fixing kit as it didnt seem to be doing anything.
Is there are simple way of fitting them? Couldnt find any guides!
Offline big al
« Reply #3 on: April 19, 2010, 11:16:08 am »
There are 4 or 5 star shaped screws if I remember correctly, 2 or 3 underneath along the chassis, and 1 on each end in the whel arches.
Then there is a LOT of adhesive sticking them on, I used a plastic ice scraper to prize mine off, but you will need something quite strong to stick them back on afterwards.
Offline holty
  • -Given: 17
« Reply #4 on: April 19, 2010, 11:29:30 am »
Yeah used alot of back to back tape and tigerseal.
The prob i had was getting the height correct, I managed to stick it a little too high and the screws didnt fit in! Had to take off and refix!
Is there are knack to fixing them on?  :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: April 19, 2010, 07:31:11 pm »
Maybe masking tape first to line everything up?. Then use a stick of chalk to mark up ?.  :happy2:
Offline holty
  • -Given: 17
« Reply #6 on: April 20, 2010, 04:09:59 pm »
like your thinking  :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #7 on: April 20, 2010, 04:35:30 pm »
..........  :happy2: hope it works.
