Author Topic: Auto Windows using key fob  (Read 4244 times)
Offline holepunch
« on: April 20, 2010, 12:25:14 pm »
During the recent hot/warm weather I have used the key remote to open the car and the windows, however it only works on the driverside window.
Do I nned to change a setting via highline comp to ensure it does both?
Offline Neimad
Re: Auto Windows using key fob
« Reply #1 on: April 20, 2010, 12:30:05 pm »
This happened to me the other day actually -- it stopped closing all but the drivers door window.  After connecting the car to a friend's VCDS cable we noticed that there were errors (DTCs) on the radio and randomly enough, clearing these made all the windows work again...  :confused:
Offline Blake-R
« Reply #2 on: April 20, 2010, 12:40:29 pm »
When doing this from the key fob do you just hold the unlock button down?
Offline Neimad
« Reply #3 on: April 20, 2010, 12:42:37 pm »
Yep, or the lock button if you want to close them. :happy2:
It's definitely an option that needs to be enabled via the highline display or VCDS though.
Offline Blake-R
« Reply #4 on: April 20, 2010, 12:53:36 pm »
Just tried it  :happy2:
Offline scotta
  • Edition 30
« Reply #5 on: April 20, 2010, 01:50:46 pm »
On my MK2 Leon if you held the lock button for a few seconds the windws would close - any ideas if VCDS can programe the golf to do that?
Offline NEWEY
    • Flickr
« Reply #6 on: April 20, 2010, 01:55:32 pm »
my mk5 does this aswell as opening with the unlock button
TSR big turbo mk5 golf gti
Offline scotta
  • Edition 30
« Reply #7 on: April 20, 2010, 02:00:31 pm »
Yeah mine does close the windows but you need to keep lock button pressed - on my leon you only had to press it once for a couple of seconds and it would fold the mirrors and close the windows.
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #8 on: April 20, 2010, 02:18:33 pm »
Scotta, think ive seen another post on this somewhere and iirc then this isnt possible via a VCDS re-code, think it requires an alarm unit with global closure feature, so require a new module or after-market unit. Shame as it would be a good feature.
Offline seckles
« Reply #9 on: April 20, 2010, 02:31:43 pm »
You mean where you hold down the unlock button and all the windows open right? On mine (57 reg MY08) there is definitely a setting in the highline comp to turn this feature on/off and I think an option for the drivers side only (tho I might getting this mixed up with the auto-lock feature!). I can't remember off-hand what it's called in the menu but it something pretty cryptic like "convenience mode" I think.
Steve
Tornado Red ED30 5Dr. Xenons, RNS510, MFSW, Rear Parking Sensors, Folding mirrors+ambient lighting, Rear Tints, Highline, Arm rest+iPod Prep
Offline robern2
« Reply #10 on: April 20, 2010, 06:10:55 pm »
well well well. It is indeed a convenience option. Works a treat
Offline Blake-R
« Reply #11 on: April 21, 2010, 01:33:19 pm »
How/where do you access the HighLine computer then?
« Reply #12 on: April 21, 2010, 10:27:08 pm »
The highline display is a full sized display. The midline is a half-sized display. If you have highline you will have extra buttons to access the onscreen menu.
