Author Topic: missfire at 5k  (Read 3382 times)
Offline Guv
missfire at 5k
« on: April 20, 2010, 07:19:35 pm »
Right,
since ive had my bluefin on when i get to 5k in first gear the car gos nuts making a buuuurrrrrbbbppp noise lol if you get what i mean lol and its misfiring i had this problem on an old supercharged bmw i had . the problem was due to the sparkplug gap ive changed all the plugs today and its still doing it . has any one got any ideas ? its driving me nuts
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: missfire at 5k
« Reply #1 on: April 20, 2010, 07:39:20 pm »
bluefin guys will be along soon, but I seem to remember that an incorrect map (manual vs dsg) may cause this.
First thing Id check is you have the right map for your gearbox type  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: missfire at 5k
« Reply #2 on: April 20, 2010, 07:51:31 pm »
is this with esp on by chance?
Re: missfire at 5k
« Reply #3 on: April 20, 2010, 07:57:13 pm »
How come? Got a miss fire at the min doing coilpacks at the weekend.  Started when i put ngk irridiums in.  put srd bosch plugs in and its not as bad but missfires when driving hard...
Offline Guv
Re: missfire at 5k
« Reply #4 on: April 20, 2010, 08:00:18 pm »
yes it is havent tryed it with it off but esp wont cause a missfire tho surely
Offline PDT
  • -Receive: 142
Re: missfire at 5k
« Reply #5 on: April 20, 2010, 08:03:04 pm »
Is it at 5k under high load? or at any throttle position?
Offline Guv
Re: missfire at 5k
« Reply #6 on: April 20, 2010, 08:03:36 pm »
under highload
Offline PDT
  • -Receive: 142
Re: missfire at 5k
« Reply #7 on: April 20, 2010, 08:07:59 pm »
I have seen this a lot laterly on the TFSi engines. I usually try and replicate the fault on the dyno, often its a missfire on coilpack number 4. Only ever see it on mapped cars as well.
I usually replace all 4 plugs, if that doesnt solve it I will change coilpack 2 for number 4 and retest, if the missfire moves to cyl2 then I know its the coil.
If you need a set of coils I have 12 brand new in boxes, original VW items as well. will sell at -20% off retail.
Re: missfire at 5k
« Reply #8 on: April 20, 2010, 08:13:59 pm »
Are you manual or DSG? Ed30 or GTI?
Have you tried it with the map removed?
Superchips have a bit of history with sending manual maps to DSG cars. Nothing fatal but quite annoying. The symptoms are similar to what you describe however on my Ed30 with stage 2 it went from about 3k until 5k at which point it pulled cleanly.
On stage 1 with the wrong map it went from 3-4.5k but was much less pronounced as the stage 2 map.
Or it might be a plug/coilpack problem but try the cheap options first  :smiley:
Offline Guv
Re: missfire at 5k
« Reply #9 on: April 20, 2010, 08:28:02 pm »
Just took her for a lil drive and its really bad with esp on with esp off you can hardly notice it
my gti is a manual with bluefin stage 2 it didnt do it with stage 1
have also changed the coils with a spare set i have and its still the same
wondering if thes plug i got today are dodgy .
« Last Edit: April 20, 2010, 08:30:12 pm by Guv »
Re: missfire at 5k
« Reply #10 on: April 20, 2010, 08:32:05 pm »
Hmmm. Sounds promising. Try it with the original plugs and see.
Saint Steve
Re: missfire at 5k
« Reply #11 on: April 20, 2010, 08:32:55 pm »
2nd that advice.
My missfire was at around 3000rpm in 6th gear travelling at a constant speed of around 70mph.
Offline Guv
Re: missfire at 5k
« Reply #12 on: April 20, 2010, 08:34:39 pm »
it done it with the original plugs thats why i got new ones today lol
think ill buy some platinum or iridium ones i think what are the best plugs to buy ?
Offline PDT
  • -Receive: 142
Re: missfire at 5k
« Reply #13 on: April 20, 2010, 08:38:04 pm »
I wouldnt try more plugs, if it was doing it with the originals, and with new ones then its likley to be a coilpack. Maybe take others advice on getting the map checked as well.
What other mods are on the car? did it do this with just stage 2 or on stage 1 as well? what have you changed to go to stage 2 other than the map?
Offline Guv
Re: missfire at 5k
« Reply #14 on: April 20, 2010, 08:41:22 pm »
cold air intake system and turbo back miltek exhaust also a forge bov adaptor. i only used stage 1 for 2 days as i wanted stage 2 in the first place and it didnt do it with stage 1
