Author Topic: Anti Roll Bar Bushes  (Read 5979 times)
Offline Janner_Sy
  • -Receive: 113
Re: Anti Roll Bar Bushes
« Reply #15 on: April 22, 2010, 05:27:02 pm »
cheers steve, ill get it up on the ramps and take a look i think.  it feels like the knock is coming from just underneath my feet in the drivers foot well, so i think  potentially it could also be a loose clamp?
« Reply #16 on: April 22, 2010, 10:19:24 pm »
....I had a knocking on the passenger side. It turned out to be a broken front wishbone bush - Extremely difficult to spot but worth checking if problem not otherwise solved.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #17 on: April 24, 2010, 10:16:54 pm »
Does anyone know how to tell which setting the arb is on?
On mine there are two holes, so if the inside hole the stiff setting and the outside hole soft?
« Reply #18 on: April 24, 2010, 10:20:30 pm »
As the lever will be longer therefore easier I think the outside is softest. I do stand to be corrected on that though. :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #19 on: April 24, 2010, 10:23:57 pm »
thats correct steve.
After 3 weekends in a row at the ring with a different ARB set up each time:  front and rear on stiff, front stiff, :signLOL: rear soft, and front soft, rear stiff, i found the front soft, rear stiff to be the the best setup.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #20 on: April 24, 2010, 10:24:43 pm »
Cheers guys, based on that mine are set on front soft / rear stiff  :happy2:
