Author Topic: Feeler thread - Group buy on Mk2 TT lower arms...................  (Read 54062 times)
Offline alex_chung
Re: Feeler thread - Group buy on Mk2 TT lower arms...................
« Reply #15 on: April 23, 2010, 04:30:03 pm »
Another Leon question. Will these fit the Leon TDI seeing its the same car chassis wise?
Alex
Offline Janner_Sy
  • -Receive: 113
« Reply #16 on: April 23, 2010, 05:32:29 pm »
cant see why not tbh.  they fit the vRS and as far as i know the vRS TDI shares the same suspension as the vRS TFSI.  might be worth checking the part numbers on etka for the tdi and tfsi lower control arms
Offline owen lcr
  • owen
« Reply #17 on: April 23, 2010, 06:57:43 pm »
does anyone know how the ball joints are fitted to the TT arms?  i know the standard ball joints have 3 fixing bolts attached but the TT ball joints dont???
http://www.audi-sport.net/vb/showthread.php?71940-TT-suspension-arms-fitted-to-my-A3!!!&highlight=tt+lower+control+arms
see the differance on the 3rd and 4th pictures.
cheers
« Last Edit: April 23, 2010, 06:59:51 pm by owen lcr »
Offline alex_chung
« Reply #18 on: April 23, 2010, 07:02:03 pm »
That is what I thought too. Does anyone have access to etka to check?
Might be interested if it does fit.
Alex
Offline QD MBE
  • -Receive: 102
« Reply #19 on: April 23, 2010, 07:02:17 pm »
Right, having seen a set of TT arms up close, you will need to buy the TT Ball joints too, as the camber adjustment is in the Ball joints.
The ball joints are bolted to the Lower wishbones.
First post is now amended.
D
Offline Janner_Sy
  • -Receive: 113
« Reply #20 on: April 23, 2010, 07:04:26 pm »
the difference is the elongated holes in the ball joints.   if your std cupra arms are identical to the tt lower arms it could be a direct swap.
this is the TT arm lower control arm number 8J0 407 151 D(same part number for each side).
get someone with etka to see what the part# is for the cupra ones
post#3 shows al the parts required. the only extra youi would need if your arms are the same would be the bolts, the ball joints and the ball joint locking plates
http://www.mk5golfgti.co.uk/forum/index.php/topic,13520.0.html
Offline owen lcr
  • owen
« Reply #21 on: April 23, 2010, 07:05:28 pm »
so you just need 6 standard nuts and bolts to fix them together?
Offline Janner_Sy
  • -Receive: 113
« Reply #22 on: April 23, 2010, 07:08:37 pm »
and the lock plate.    but you need to confirm that your lower arms are the same. if not the holes might not line up correctly
that last link i posted has the the part#'s for all the kit required
Offline QD MBE
  • -Receive: 102
« Reply #23 on: April 23, 2010, 07:12:02 pm »
I think we may have stumbled on a cheap way of adding camber to the Cupra/S3.  Just add TT balljoints and lock plates.
The P/N's are the same!  So should fit!
I can do the ball joints, bolts and lock plates separately........................... Will come up with a quote too!
Offline Janner_Sy
  • -Receive: 113
« Reply #24 on: April 23, 2010, 07:15:28 pm »
jammy gits.
@ owenLCR you should maybe post this on SCN as im sure there would be alot of guys interested.  You never know prices could get dropped further still.
Offline gazbutS3
« Reply #25 on: April 23, 2010, 07:16:50 pm »
Was just thinkin that :smiley:
Offline QD MBE
  • -Receive: 102
« Reply #26 on: April 23, 2010, 07:17:36 pm »
Will get a quote tomorrow.
D
Offline owen lcr
  • owen
« Reply #27 on: April 23, 2010, 07:24:11 pm »
@ STOKEBALLOON ~ superb, if you can get prices for me mate that would be great.  As VRSY says i will need to double check P/N's but i am nearlt positive that the arms are the same on cupra/s3.
@ VRSY yeah mate i will do, looks like this could work out a cracking mod for well under £100
cheers chaps
Offline RobH
  • Revo stg 2+
« Reply #28 on: April 23, 2010, 07:29:52 pm »
jammy gits.
This would be an awesome cheap mod if all goes to plan and im sure there would at least 10 on scn interested  :jumpmove: :jumpmove: :jumpmove:.
Offline owen lcr
  • owen
« Reply #29 on: April 23, 2010, 08:00:08 pm »
tried to post a note on the seat forum but it got deleted as it was apparently a group buy, even although it was just a note pointing them to this thread :sad1:
