November 24, 2024, 03:23:04 pm
All Things Mk5
How to Guides / Troubleshooting
Removing Radio.....
Topic: Removing Radio..... (Read 2952 times)
Ifti
Removing Radio.....
April 22, 2010, 10:17:12 pm »
I dont have the top centre vent in my MK5 as I dont have Climate Control. I just have a spare tray thingy.
Does anyone have a guide on how I can remove this can get down to the radio so I can install my Parrot kit please?!
SteveP
Just look at my post count
-Given: 117
-Receive: 340
Re: Removing Radio.....
Reply #1 on:
April 22, 2010, 10:20:10 pm »
Just the same as with the vent as far as I am aware, you just need to just a trim removal tools to lift out the tray, then you can remove the screws holding the middle vents trim in place.
Ifti
Reply #2 on:
April 23, 2010, 09:02:18 am »
I may try this on the weekend - Im assuming I can just use any flat end to pry the tray up??
Should i start from the front, or the rear, of the tray? Or does it not make a difference?
SteveP
-Given: 117
-Receive: 340
Reply #3 on:
April 23, 2010, 09:04:00 am »
I would start at the rear of the tray
Ifti
Reply #4 on:
April 23, 2010, 09:45:25 am »
Do I need to disconnect the battery or anything before I begin??
Nasir
Reply #5 on:
April 23, 2010, 10:23:46 am »
There are 2 screws underneath the rubber mat. Remove them and then pull the tray, then follow the normal procedure.
Ifti
Reply #6 on:
April 23, 2010, 10:25:10 am »
Cheers mate - do I need to do anything with the battery before I remove the radio, or am I ok to just unplug it to connect the parrot it?
Nasir
Reply #7 on:
April 23, 2010, 11:04:48 am »
I didn't remove it but I'm not sure if you have to. Have you ever taken apart the dash?
Ifti
Reply #8 on:
April 23, 2010, 11:14:31 am »
Nah never!
Ive ordered my Parrot kit (with the VW loom) and have been quoted £100 for just the installation!!
Hence I want to have a go myself!
Yellow
Taking part
-Given: 0
-Receive: 2
Reply #9 on:
April 23, 2010, 12:21:01 pm »
Where are you based?
Yellow
Taking part
-Given: 0
-Receive: 2
Reply #10 on:
April 23, 2010, 12:24:59 pm »
If you're near the midlands I'll give you a hand, I did mine yesterday
Ifti
Reply #11 on:
April 23, 2010, 12:53:09 pm »
Im just outside of London mate - near Stanstead.
Cheers for the offer though
Garth
Won't Shut up.
-Given: 4
-Receive: 14
Reply #12 on:
April 23, 2010, 03:18:12 pm »
I's a REALLY easy install putting in a Parrot kit. There's no way it should cost £100. Give it a go yourself and you'll be suprised how simple it is.
It took me about 20mins and that was being slow and careful!
My GTI Build Thread
My TT Restoration Thread
My S4 Tidy up thread
Please help my autistic son
Ifti
Reply #13 on:
April 23, 2010, 06:19:18 pm »
Im assuming I need this as well?......
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260587216655&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dm570%26_nkw%3D260587216655%26_fvi%3D1&_rdc=1
I think I can get the radio out fine now - any guides on the wiring etc on installing the parrot, ie. where/how its all connected up?
SteveP
-Given: 117
-Receive: 340
Reply #14 on:
April 23, 2010, 07:16:07 pm »
99% of it is plug and play.
You just need to connect the loose red wire to a 12v switch source, this can be found either on the back of the climate control panel or the fuse box.
All Things Mk5
Removing Radio.....
