Author Topic: a slight problem  (Read 2788 times)
a slight problem
« on: April 24, 2010, 09:16:50 pm »
for a while now the n/s/f door won't open from the out side when i unlock the car,but it will open from the inside..if i spray the mechanism with wd40 it locks and unlocks ok for a while then it does it again..got the car scanned today..is this a easy fix and what will i need
VIN: WVWZZZ1KZ5W160387   Mileage: 66910km/41575miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 KC    HW: 028 101 190 3
   Component: R4 2,0L EDC 0000SG  8457
   Revision: 12345678    Serial number: VWZ7Z0D1201563
   Coding: 0000072
   Shop #: WSC 00784 210 86038
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023170
   Shop #: WSC 01392 785 00200
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001252733
   Coding: E5898F0600041800001400001400000000087F075C
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 08 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD027AV0
   Coding: 0012344
   Shop #: WSC 01373 785 00200
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 521 0050
   Coding: 0000012
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 872 K
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0003403
   Shop #: WSC 12345 123 30350
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104B180177
   Coding: 3D3F0B00070003
   Shop #: WSC 07975 795 00500
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VDD 4312
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01706 - Switch for Mirror-Adjust (E43)
            008 - Implausible Signal - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.3       1502
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80C802087F2D0F0FC85FC69010
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
            012 - Electrical Fault in Circuit
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
End   ---------------------------------------------------------------------
Saturday,24,April,2010,10:19:56:27638
VCDS Version: Release 908.2
Data version: 20100326
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 7D
   Coding: 0000072
   Coding: 0023170
   Coding: 00065493
   Shop #: WSC 00000
   Coding: 00217125
   Shop #: WSC 00000
   Coding: 0012344
   Coding: 0000012
   Coding: 0003403
   Coding: 0000052
2 Faults Found:
   Coding: 0000052
2 Faults Found:
   Coding: 0000016
   Coding: 0000016
Saturday,24,April,2010,10:23:07:27638
Chassis Type: 1K0
   Coding: 0000072
Readiness: 0 0 1 1 1
   Coding: 0023170
   Coding: 00065493
   Shop #: WSC 00000
   Coding: 00217125
   Shop #: WSC 00000
   Coding: 0012344
   Coding: 0000012
   Coding: 0003403
   Coding: 0000052
   Coding: 0000052
   Coding: 0000016
   Coding: 0000016
Re: a slight problem
« Reply #1 on: April 25, 2010, 09:40:30 am »
anybody :sad1:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #2 on: April 25, 2010, 09:51:08 am »
I would say this bit is the starting place: -
Quote
   Coding: 0000052
2 Faults Found:
Only one of those fault codes is listed - http://wiki.ross-tech.com/wiki/index.php/00929
