Author Topic: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....  (Read 438921 times)
Offline lm_gauci
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: NQS BBK A Not Quite So Big Brake Kit..With Install Pics
« Reply #751 on: January 20, 2013, 11:58:46 pm »
theyre boxster S pads unfortunately....
  • Trader - 2014
  • -Receive: 130
« Reply #752 on: January 21, 2013, 12:19:00 am »
Working on a 335mm rear which'll be low cost, uses a separate handbrake Caliper which are expensive.
First kit goes on a TTRS this weekend funnily enough
any more info/news??? :happy2:
Yes well the TTRS has an extra track width of 10mm per corner allowing me to get all sorts of bracketry in there to replace the OEM setup completely with RS6 335mm rear drilled discs, porsche calipers and brembo handbrake calipers. Just done 9 kits for now and they've all sold
Working on something more cost effective for MK5/6/R32 the problem is these RS6 discs are £600 retail but are dimensionally perfect and directional
But heres Jamies TT with the kit fitted, the other 8 kits ship this week all over from Harrogate to Sydney Australia
  • Trader - 2014
  • -Receive: 130
« Reply #753 on: January 21, 2013, 12:36:50 am »
Ok the other mod that I thought might be of interest to the NQS users is a rear caliper upgrade.
Basically the standard GTI Caliper has a 38mm piston and is configured for a 12mm wide disc.
Next upgrade along is the S3 or R32 setup goes to a 41mm piston and a 22mm wide disc
So what if we had a 41mm version of the stock GTI caliper which was plug and play.
Dont forget we always talk about diameter when we talk about our discs, brake engineers never discuss diameter as it doenst matter for sh1t.
Radius and effective radius at that is where its at.
So we use a 286mm disc instead of a 310mm disc thats a 12mm reduction in radius, if we use the new caliper that hydraulically is the same as the S3 rears, we in essence get S3 bias for GTI money.
So in keeping with the Low Cost high performance ethos of the NQSBBK we now have an alternative upgrade path which weighs an unsprung 9KG less for practically speaking the same performance.
Its here.....we've got some they're off a Caddy van, theres an amount of modding to do to them as they need the handbrake bracketry and feed pipe swapping over which normally works as part of a refurb process. Jonny at BCR has two or three sets stripped down.
Theyre on a members car on here, he may/may not want to cough to running them. The rears were fitted at the same time as the NQSBBK was so difficult to do a like for like but safe to say with the 41mm rears and the NQS the car feels planted under braking as you would expect.
PM me for more info or we can discuss it on here
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....
« Reply #754 on: January 21, 2013, 06:59:48 am »
Due to balance questions this might be of interest for some of you.
Hope I did get all the collected data right.
piston size/area
1. stock front caliper:
Golf/GTI - Ate FN3 54 mm caliper: 2290 mm²
S3/R32/R - FNRG 57 mm: 2552 mm²
2. aftermarket - proper match:
Boxster: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
Brembo GT caliper A: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
Stoptech ST-40: 38 mm + 34 mm > 908 mm² + 1134 mm² = 2043 mm²
3. aftermarket - poor match:
Forge: 707 mm² + 1046 mm² + 1164 mm² = 2917 mm²
Q7/Touareg/Cayenne (three variants):
34/36/38 mm : 907.920 + 1017.876 + 1134.115 = ~ 3060 mm²
32/36/38 mm : 804.248 + 1017.876 + 1134.115 = ~ 2956 mm²
30/34/38 mm : 706.858 + 907.920 + 1134.115 = ~ 2749 mm²
4. master cylinder diameter:
- 22,22 mm >  388 mm² (Mk.V GTI)
- 23,81 mm >  445 mm² (Mk.V R32, Mk.VI GTI, Golf R)
- 25,40 mm >  507 mm² (RS3 + TT-RS)
If you know the piston diameter: Pi * radius² = area
« Last Edit: January 21, 2013, 09:04:27 am by the bruce »
"You get what you pay for."
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #755 on: January 21, 2013, 07:39:02 am »
Dave, how about opening a new thread?
I must say I am interested in this... Will we keep the stock discs or will these be replaced with vented ones?
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #756 on: January 21, 2013, 08:48:55 am »
I'd bet if a stock Caddy caliper is used it needs to be a solid rotor.
ps
Brembo caliper added
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #757 on: January 22, 2013, 04:22:53 pm »
piston size/area
AP Racing 6-pot CP7068-00 (355x32 ) > 2350 mm²  :happy2:
  • Trader - 2014
  • -Receive: 130
« Reply #758 on: January 22, 2013, 08:26:49 pm »
GTI is 23.8mm All models
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #759 on: January 22, 2013, 10:43:31 pm »
Thx, Dave.  :happy2:
Refering to ETKA there are both 22.22 and 23.81 mm. Possibly some GTIs exported overseas had the 22.22.
Found some more - Boxster S and 993/996 Turbo:
piston size/area
Boxster S: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
993 Turbo: 36 + 44 mm > 1018 mm² + + 1520 mm² = 2538 mm² (on the edge)
Brembo GT Satteltyp A: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
996 Turbo: 40 + 44 mm >  1257 mm² + 1520 mm² = 2777 mm²
- 22,22 mm >  388 mm² (some Mk.V GTI, Mk.V + Mk.VI Golf)
- 23,81 mm >  445 mm² (Mk.V R32, Mk.V GTI, Mk.VI GTI, Golf R)
« Last Edit: January 22, 2013, 10:45:20 pm by the bruce »
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #760 on: January 23, 2013, 02:56:01 pm »
So? What is needed & Cost ???  :party:
New Thread for the NQSBBK would be good idea  :happy2:
MK2 PRE-FL SEAT LEON TFSI SPORT - APR K04
Offline jimk04
« Reply #761 on: January 24, 2013, 09:13:56 am »
996 turbo do work well
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline Dan648v
  • -Given: 28
« Reply #762 on: January 24, 2013, 09:16:23 am »
Interested in this rear nqsbbk! And more importantly who is getting it in Harrogate because I don't know anyone in my town on here??.....
« Reply #763 on: January 24, 2013, 09:16:53 am »
Even if you do say so (and engineered it) yourself!  :P
Offline jimk04
« Reply #764 on: January 24, 2013, 09:24:25 am »
No Mike mine are just 996. WasWas referring to yours!
